advanced timing with zex
Old Dec 12, 2006 | 11:04 PM
absoundlab
http://forums.maxima.org/showthread....58751&t=383168
can I run advanced timing with a 75 dry shot of zex?
Old Dec 13, 2006 | 08:48 AM
grey99max's Avatar
LandShark has Cosworth
Once......
Seriously, research this on suppliers' web sites. To run higher shots, you need to pull timing, not add timing.
Old Dec 13, 2006 | 09:06 PM
SuperStasiu's Avatar
I think if hes only advanced to 17 degreese and only running a 75 shot he could do it but he'd be safer with a wet kit. Anything above 75 i'd go back to stok 15 degreese since your a 5th gen.
Old Dec 13, 2006 | 10:02 PM
streetzlegend's Avatar
timing advance+nitrous=not good. dont even attempt even if others say its safe. just not worth risking. use 2 step colder plugs, leave stock timing.
Old Dec 18, 2006 | 08:14 AM
absoundlab
ok im not going to advance timing at all
so if im going to leave stock timing then use a 2 step colder plug (where can I get these and do you have a brand and model 3?)
If I retard timing do I use a 1 step colder plug?
Also as a daily driver car that im not going to using the zex all day long what do you think the best set up would be for running a 75hp shot
which plugs do you think would be best and what timing?
Old Dec 18, 2006 | 10:56 AM
grey99max's Avatar
To run a 75-shot when the mood strikes you, I would:
1. Be sure you have premium gas in the tank.
2. Leave timing stock.
3. Use 1-step colder NGK copper plugs - any parts store can verify P/N. Cheap=$1.50 each. 2-step colder are better, not essential for 75-shot.
4. Replace fuel filter, air filter.
When you want to go beyond 75-shot, be prepared to buy more stuff. Lots more. Check my sig.
The key to engine survival is to NOT have pre-ignition or detonation. Fuel, timing, plugs are parts of the equation. Done correctly, with a NX wet kit, nitrous is very reliable and powerful. Otherwise, replacement engines are cheap and easy to find.
Old Dec 18, 2006 | 10:59 AM
Kevlo911's Avatar
Kevlo for President
Base timing does NOT affect WOT.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
kmitchel
Oct 28, 2015 09:46 AM
Starrider
Sep 17, 2015 07:26 AM
rbaker100
Aug 31, 2015 11:09 AM
305head
Aug 26, 2015 09:03 PM
