some new toys for my nitrous kit
Old Mar 12, 2007 | 07:46 PM
  #41
absoundlab
ya i bought the cf lid from nax the front lip got molded to the front bumper and repainted the sides got repainted as well as the rear. I haven't installed anything yet. the front grill got painted black and the cf lid is getting recleared.
Old Mar 13, 2007 | 08:37 PM
  #42
NiZMo1o1's Avatar
sweet!! keep us updated well I guess its your time to shine !!
Old Mar 27, 2007 | 06:15 AM
  #43
absoundlab
I started installing a few things. I mounted the 2 solenoids and the fuel switch. I also put in the water injection pump.
tapped into the fuel line
Old Mar 27, 2007 | 06:53 AM
  #44
grey99max's Avatar
LandShark has Cosworth
The fuel tap looks pretty good, but is that teflon tape I see on the AN adapters in the solenoids?
Think about what happens when you tighten down those adapters and bits of the tape get cut off inside the solenoids. When you spray, those bits can move down the hoses and into the jets. Blocking a fuel jet can make a really bad day at the track.
Some form of Permabond is commonly used here - to change adapters, you can heat them with a propane torch, then unscrew from the solenoid.
Maybe some other users can discuss this.....
Old Mar 27, 2007 | 07:07 AM
  #45
absoundlab
well I read the booklet that came with the kit and there was a diagram that shows you want to put tape on.
Old Apr 8, 2007 | 07:53 PM
  #46
absoundlab
Old Apr 8, 2007 | 08:02 PM
  #47
t6378tp's Avatar
Turbo 3.5
I use teflon paste only for my truck and max, hell the speedshop near my house will not even sell you tape if your running nitrous
they rather you get the tape somewhere else that way you can not blame them later
Apr 16, 2020 05:15 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
Pied
Sep 26, 2015 03:29 PM
