Crankshaft position sensor??
Old Feb 9, 2007 | 03:52 PM
babymac's Avatar
BOOST 4 LIFE!
I was out testing my spray and all was fine. I come to a stop and the car starts to misfire?? Anyway I make it home and the code I got was for crankshaft position sensor(reference). How would the nitrous make this go bad? or was it just a coincidence?
Luckily I have one and I'll be replacing it and my plugs tomorrow and hope that's it. :fingerscrossed:
Old Feb 10, 2007 | 12:10 PM
babymac's Avatar
BOOST 4 LIFE!
Problem solved. I would still like to know how nitrous would cause a crankshaft position sensor to go bad?? Anyway my nitrous project is still a go!
Old Feb 11, 2007 | 11:59 AM
babymac's Avatar
BOOST 4 LIFE!
Well I went out again and did some more testing and everything was fine until today I go start the car and it starts to misfire again. Anybody have any ideas what this could be?? I don't have any cel's yet, but will probably get one soon.
I am really getting frustrated with this and am about to say "F" the whole nitrous thing.
Old Feb 12, 2007 | 06:51 AM
NmexMAX's Avatar
dot dot dot ...
Check the wiring ahrness to the CPS.
Old Feb 12, 2007 | 01:29 PM
babymac's Avatar
BOOST 4 LIFE!
Where at? The harness near the sensor is wrapped in that plastic covering stuff.
This is going to be a real pain I can tell. Thanks for the advice
Old Feb 12, 2007 | 04:26 PM
t6378tp's Avatar
Turbo 3.5
Did you ever check your plugs and coils, I remember you saying that the car was misfiring when you would rev it around 7k, if this is the case and you maybe getting enough spark for normal driving but if the spark is weak it will cause you to misfire
My car was misfiring couple months ago but it was just a dirty connection to the coil. I just cleaned the connection and plug and it was fine
Also I do not know what shot you are running but if your gaps on the plugs are too big the nitrous will just blow them out
Good luck
Old Feb 12, 2007 | 04:35 PM
babymac's Avatar
BOOST 4 LIFE!
I just replaced the plugs after it started doing it the first time and it's still doing it. I definitely think it is a coil but I have no codes. I think thats because its intermittent, it doesn't do it all the time, but I am definitely running one cylinder short because you can really tell on acceleration.
btw I might be picking up a 92 se-r in the meantime. sr20de+a big fat shot of juice!
Old Feb 12, 2007 | 05:07 PM
t6378tp's Avatar
Turbo 3.5
I did not get a code either, but I could hear and smell it even at idle, do the easy and free things 1st check all related connections make sure everything it clean and tight then test your coils, battery and alternator if you are not getting the proper voltage things will not work correctly may sound silly but sometimes it's that easy
also does this only happen when you spray. I have a extra front and rear coil if you want to test them or you can get 1 at the junkyard for like 20bucks at the most
TallTom
57
Oct 14, 2025 05:16 PM
hayne
Oct 5, 2015 11:53 AM
salty318
Sep 28, 2015 07:22 PM
zmcneely13
Sep 26, 2015 02:26 PM
