View Poll Results: Which Nitrous Window Switch do you have?
ZEX
0%
NX
0%
MSD
83.33%
Other (please list)
16.67%
Voters: 6. You may not vote on this poll
Nitrous window switches.
Old Feb 13, 2007 | 06:10 PM
Maximahappy22's Avatar
I was just wondering which window switches you guys have and are they easy to set up?
I looked at the install instructions for the MSD and NX wondow switches and just got confused about how to go about installing them so that it can read my rpm's...
Any help is appreciated.
Alex
Old Feb 13, 2007 | 06:51 PM
grey99max's Avatar
LandShark has Cosworth
Alex
Pin 5 on the ECU is the tach signal that goes to the MSD - I use the MSD 8969 for various things. Program in the lower and upper RPM settings and set it to "6 cylinder" mode, use the yellow wire to provide an active ground, and you're good.
Old Feb 13, 2007 | 09:13 PM
2002AltimateV6's Avatar
+1 on MSD.
Old Feb 13, 2007 | 10:48 PM
alright cool so ill probably get the msd since it is the cheapest, simplest, and best according to you all...
Thanks for the info! more is welcome...
Alex
Old Feb 13, 2007 | 10:56 PM
hey 2002AltimateV6,
maybe you could help me install my nitrous kit and msd window switch later down the road if you are looking for something to do...
I should have it in about a month or so. let me know.
Old Feb 14, 2007 | 11:27 AM
absoundlab
msd window switch with 3000 and 6500 pills
Old Feb 14, 2007 | 11:44 AM
505max94se's Avatar
I vote for a Dyno Tune window switch.
http://www.dynotunenitrous.com/store...?idproduct=194
Old Feb 14, 2007 | 03:54 PM
Thanks for the replies.
I am going to go with the MSD Digital Window Switch (PN 8969).
But if i want the nitrous to be dissabled until desired RPM would i ground the yellow wire or gray wire? (http://www.msdignition.com/pdf/8969_frm25515.pdf)
Thanks for your help.
Alex
Old Feb 15, 2007 | 01:48 PM
hey 2002AltimateV6,
WOW! A local! Lol! Sure man, I can try, lol.
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
Luev
Sep 30, 2015 11:50 PM
