Nitrous noob question:
Old Apr 6, 2007 | 10:31 AM
MaxBoost925's Avatar
Drug Money
Is it ok If I use my brand new OEM NGK plugs and also running 17 degree timing advance if I run a 75 shot ZEX kit?
I hear all these things about people using colder plugs but I just want to ask a stupid question before I actually do something stupid.
Old Apr 6, 2007 | 10:37 AM
Max_Out's Avatar
Under the radar
Umm its my understanding that running nitrous with a timing advance would cause detonation. Someone else care to chime in? the OEM plugs are fine, if you plan on running under a 50 shot or so. Anything higher i would go a step colder or two.
Old Apr 6, 2007 | 02:27 PM
xlcrew's Avatar
I’m Back
i would strongly suggest to use one step colder copper plugs. you can get the plug number off of jime's website
Old Apr 6, 2007 | 03:34 PM
t6378tp's Avatar
Turbo 3.5
advance timing + nitrous = new engine
55shot stock heat range plugs will be fine
75shot 1step colder and regap them
Old Apr 7, 2007 | 04:23 AM
BLK2BLU's Avatar
I am a Noob to nitrous but, Is it the base timing?...if so, that advance should only affect anything under 2K RPM's. Unless you are spraying under 2K (not good) then you will be fine. This is the way I undersand it all.
Old Apr 7, 2007 | 08:29 PM
Tatanko's Avatar
Bacon Lover
It is indeed 17 degree base timing on 5th gens.
Old Apr 8, 2007 | 05:05 PM
Drug Money
So it's OK to run my 17 degree timing which is still within OEM specs?
I'm getting 1 step colder NGK plugs as well when running 75 shots.
Old Apr 8, 2007 | 05:41 PM
Max_Out's Avatar
Under the radar
I think you will be fine, ive seen nitrous on 5th and 5.5 gens. And im running on stock timing, but im not sure what the stock timing is on the VQ30DE
Old Apr 8, 2007 | 05:44 PM
Drug Money
I believe it ranges from 14 deg up to 17 deg within OEM specs.
Mine was at 14 when my mechanic adjusted it.
Old Apr 17, 2007 | 01:17 AM
mastercater7's Avatar
VQ35 FTW
would NGK iridiums be ok for a 75 shot?
Old Apr 17, 2007 | 08:18 AM
Maximahappy22's Avatar
Nah stick with the OEM or V-type NGK coppers, 2 steps colder of course. Gap to about .36-.40
Old Apr 17, 2007 | 04:54 PM
viper32909's Avatar
Can you use your OEM NGK plugs yes, would i recommend it "NO". If they are platinum type then a Definite "NO". Just get some NGK coppers and call it a day. It won't hur t anything and they don't cost much.
Enjoy the spray
AaronL
Nov 15, 2020 11:52 AM
Balkins
Feb 1, 2016 12:45 AM
sake1bs
Sep 19, 2015 09:32 PM
Hawkeye61
Aug 12, 2015 06:45 PM
Habibshaib
Aug 6, 2015 01:19 PM
