In your opinions how necessary are these?
Old Jun 5, 2007 | 07:32 AM
Gle03Max's Avatar
* Please only people that have knowledge and experience with nitrous respond, I dont want random people throwing answers out ******
Ok I have searched but none of my searches answer my questions.
I have just purchased the zex wet kit 82021 for my 2k3 6SP Max
There are three things that I know are good to have but I wanna know how necessary they are. If you had to pick what order would you get them in?
- I do plan on buying all the following but only have so much money and want to get the best bang for my buck.
1. Zex Bottle Warmer
2. Zex Liquid Filled Nitrous Gauge
3. Zex Remote Bottle Opener/Closer
Thanks alot for your help.
Old Jun 5, 2007 | 08:02 AM
mtrai760's Avatar
'Trynna' is not a word
Get the bottle warmer and the gauge. Remote opener is nice but not a must have.
Old Jun 5, 2007 | 08:10 AM
Gle03Max's Avatar
Do I need these right away or can I wait like a month or so?
Old Jun 5, 2007 | 08:15 AM
mtrai760's Avatar
IMO you should get them right away. Proper bottle pressure is a must for safe nitrous operation. If your not at the proper bottle pressure, your not going to make proper power. Why waste the nitrous if its not making the power you want it to? A pressure gauge will show you that your at the proper level and ready to use.
Old Jun 5, 2007 | 08:19 AM
Gle03Max's Avatar
So should I just get the gauge for now? I didnt see anything in your second post about the bottle heater.
Old Jun 5, 2007 | 08:44 AM
mtrai760's Avatar
Sorry, thats what I meant by proper bottle pressure. The only way to get it is with a bottle heater. Heating the bottle increases the pressure of the nitrous inside, you need a bottle heater to do that properly.
Old Jun 5, 2007 | 08:45 AM
Gle03Max's Avatar
Alrite man I took your advice and now I have ordered the Zex wet kit, Zex bottle warmer, and Zex Liquid Filled gauge.
Anything else you would recommend either immediately or in the near future?
Thanks again for the help.
Old Jun 5, 2007 | 08:46 AM
Gle03Max's Avatar
For the gauge, it has to be inbetween 900 and 1100 psi am I correct?
Old Jun 5, 2007 | 10:10 AM
absoundlab
get the gauge now its $35 on ebay and the heater get it whenever you can. It will help out alot with bottle pressure. The remote bottle opener it would be nice to have they are about $200 and not a must have.
Old Jun 5, 2007 | 11:08 AM
Gle03Max's Avatar
I got the heater and gauge and am just gonna wait for the bottle opener.
on a side note, what are some good safety precautions i can do with the nitrous? ie. fuel cutoff switch or something?
Old Jun 5, 2007 | 11:44 AM
absoundlab
yes a fuel pressure safety switch would be good. if while spraying your fuel pressure drops the system will shut off
Old Jun 5, 2007 | 12:30 PM
Gle03Max's Avatar
Originally Posted by absoundlab
yes a fuel pressure
How do I do that? Or what do I have to buy?
Old Jun 5, 2007 | 12:50 PM
streetzlegend's Avatar
ebay should have fuel pressure safety switch, althouhg if for some reason your fuel gets cut off, by the time the switch reacts your engine is already blow, how ever, having your fuel pressure suddenly drop is not likely unless you have a really crappy fuel pressure regulator.
Old Jun 5, 2007 | 01:24 PM
EteRnity059's Avatar
Boosted?....
I would recommend getting a/f gauge to make sure you don't run lean. Wideband would be ideal but costly. I personally got a window switch for mine and it was set to spray at 3000rpm -6400rpm at full throttle.
Make sure you are getting at least 1 step colder copper plugs as well and that they are properly gapped.
Old Jun 5, 2007 | 04:10 PM
t6378tp's Avatar
Turbo 3.5
imo in this order get a gauge, bottle warmer, 1step colder plugs and if you plan to go higher than a 75shot and walbro fuel pump and window switch
happy spraying
Old Jun 5, 2007 | 06:51 PM
Gle03Max's Avatar
Thanks for the responses guys!
For now until I get it tuned and upgrade other things it will stay at a 55 shot.
Wont my car kinda run like crap if I put copper plugs in my car since its an 03 and calls for iridiums?
I thought on zexs website it says you dont need colder plugs unless higher than a 55 shot?
May be a stupid question, but how exactly does a window switch work?
Old Jun 5, 2007 | 08:15 PM
t6378tp's Avatar
Turbo 3.5
trust me you will go to a higher shot and quickly
stock plug should be fine with a 55shot, I did not notice any changes in my plugs till I went to a 65shot then I switch to a colder plug in the winter or on cooler days the car does take alittle longer and I mean just alittle to warm up but other then that nothing else changed but I do have a 97
and a window switch will allow you to control what rpm the nitrous will turn on and off
Old Jun 6, 2007 | 03:14 AM
Gle03Max's Avatar
Alrite thanks man.
So anyone here with a VQ35 use copper plugs?
REDinLV
Aug 15, 2024 12:30 AM
dvcamp
Sep 18, 2015 10:17 AM
ac max 92
Sep 17, 2015 07:35 AM
