well i almost blew it up
Old Mar 4, 2008 | 06:41 AM
xlcrew's Avatar
I’m Back
hey guys i went through and put my nitrous back in my car over the weekend and got it running saturday night. i have a NX wet kit that i have jetted for a 100 shot. i went through and put in 2 step colder copper plugs, had them gapped down to .035 and turned the fuel pressure up 2 pounds to 45 psi all full throttle. well i went to race a srt4 pushing 20 psi and we went from from a 40 roll. he honked it off and i hit it and jumped out bout two cars, then went to third and the car started to bog and run like it wasn't on 6 holes so i let off and pushed in the clutch and when i did the car died. so i pulled over did a visual check of everthing that i could and didnt see anything wrong. so after a minute of trying the car refired and ran fine. i went to my shop yesterday to take the plugs out and check them. well i had a lot of detonation. the center plugs on both banks part of the ground strap was gone. i'm a little nervous about spraying that much again. it just seemed weird that i was able to spray a 75 shot with no problem. i'm going to get a few more things checked out on my car and probably change my fuel pump. i have a walbro 255 in there but it's been in there for bout 4 years, and my mom has run it dry twice. so i'm wondering if it has enough to supply the pressure just not the volume. any input would be great. thanks.
Old Mar 4, 2008 | 07:22 AM
t6378tp's Avatar
Turbo 3.5
maybe the fuel soleniod was sticking or clogged
Old Mar 4, 2008 | 07:31 AM
xlcrew's Avatar
I’m Back
i just got the kit back from nitrous express from having them rebuilt because of that problem with the nitrous solenoid
Old Mar 4, 2008 | 02:42 PM
t6378tp's Avatar
Turbo 3.5
well maybe the electrical connection for the fuel soleniod is bad and it cut's in and out
Old Mar 4, 2008 | 03:17 PM
xlcrew's Avatar
I’m Back
possible, that is one of the things i'm going to go through and redo is all the wiring. it was just really scary there for about 10 minutes when the car wouldn't refire.
Old Mar 4, 2008 | 05:06 PM
t6378tp's Avatar
Turbo 3.5
I would suggest getting this it's much better than a fpss, also a incabin or out of the hood fuel psi gauge. this is handy cause your pump could be dying and not able to handle the load under spray but if you do not have this gauge you will never see it less your on the dyno
http://www.dynotunenitrous.com/store...p?idproduct=67
Old Mar 5, 2008 | 06:49 AM
xlcrew's Avatar
I’m Back
that's on my list of things to buy from them i'm also going to get a wideband and their rpm window switch. i actually just installed a dynotune kit for a budy of mine and i like there stuff.
Old Mar 5, 2008 | 08:41 AM
grey99max's Avatar
LandShark has Cosworth
At a 100-shot, that sounds like preignition to me. I have a good collection of cold plugs with vaporized ground straps,
The cure for me was cutting back the ground straps, gapping again at .035, and using a good race gas to spray with. Sunoco 104 ( blue) works well for up to a 150-shot, although either the plug gap needs closed down more or you wire in a voltage booster for the coils. Then I could run a .035 gap at 150-shot time after time - on a stock ECU.
Old Mar 5, 2008 | 09:22 AM
t6378tp's Avatar
Turbo 3.5
I took it for granted his ground straps were cut. I am running a 100shot right now and never had a problem.
I have 2 steps colder side gapped plugs set to .035 with a walbro 255 and fjo nitrous controller
Old Mar 5, 2008 | 09:29 AM
xlcrew's Avatar
I’m Back
i had 101 fuel in the car, i had bout 5 gallons of it
Old Mar 5, 2008 | 04:00 PM
kevin007's Avatar
You should always prime your gas line when you change your fuel jets and when you have'nt run your nitrous in a while, sometimes air can get into the gas line and cause a gas spike making you run lean.
Old Mar 8, 2008 | 09:54 AM
maxresurrected
thats one of my nightmares...that really sucks man..hope everything works out
Old Mar 13, 2008 | 09:56 PM
Snypa's Avatar
purge it sometimes.
Old Mar 18, 2008 | 05:12 PM
Juiced SE-R's Avatar
Hopefully when the max is tuned and ready to go again Bryan with the SRT4 will want a rematch. If not we will go find something else for you to pick on lol..
Old Mar 18, 2008 | 11:44 PM
dazalfolks's Avatar
If you wanted to go the cheaper route, you could opt for a water/methanol injection kit. You could hook it up to the rpm switch you were going to use to engage your nitrous.
tsi6001
Oct 3, 2022 10:23 PM
jskirwin
Jun 8, 2016 08:49 AM
QueensMAX
Sep 15, 2015 04:14 AM
kjlouis
Sep 14, 2015 11:22 AM
