Running E85 with spray?
Old Jan 16, 2009 | 09:02 AM
i30dvr's Avatar
Has anyone ever tried running e85 with or without spray? My question is because of the octane of e85 and its price compared to "race gas" there is a station somewhat locally and i was thinking about trying it. I was going to try and put like 5 gallons in first..any downside on running e85 for engine or electronics?
Old Jan 16, 2009 | 09:10 AM
AceofSpds's Avatar
wat
You will need to be tuned to run the e85, otherwise it would lean out, it has less btu's than gasoline. I think it takes 1.5x the amount of e85 to equal regular gas.
Old Jan 16, 2009 | 11:05 AM
grey99max's Avatar
LandShark has Cosworth
You could call NX and ask for recommended jetting. Remember to remove all gasoline from the tank before filling with E85 - otherwise your nitrous/fuel ratio will be way off.
Old Jan 16, 2009 | 11:14 AM
i30dvr's Avatar
ok what about just running e85 with no spray....any advantages or would it burn it up? i am tuning myself so i would be able to tell if its running lean via wideband but idk if its too high of an octane level
Old Jan 16, 2009 | 11:39 AM
grey99max's Avatar
It won't be too high octane - E85 is about 108 octane, according to guys I know that use it in turboed cars. High octane won't hurt motors by itself.
You would have to run a much richer load than straight gas - start with 50% more injector time. Alcohol actually runs much cooler than gas - but won't start in cold weather. That's one reason for the 85% alcohol instead of 100%.
Brazil is real big on alcohol fuels - they use 100% for driving but have a small separate gas tank that the computer uses to start the car then switches to alcohol when warm enough. Discovery-channel knowledge, you see.
Old Jan 16, 2009 | 12:29 PM
i30dvr's Avatar
damn ahah well i can't control my injector time right now because i'm not running the greddy emu....good to know though cause its prolly not a good idea to run it in 35 degree and below weather.
Old Jan 17, 2009 | 04:06 PM
maxgtr2000's Avatar
KH3 by popular demand
Found this thread through google. http://www.legacygt.com/forums/showthread.php?p=2208417
Seemingliy if you add a little more gas to the mixture you shouldn't have any problems, geographical location matters also, one guy said it the car started in 5 below temps. Yes you will need double the injector capacity you have now, but e85 seems to be good fuel for boosted cars.
Old Feb 6, 2009 | 10:35 AM
rotaryfan04's Avatar
I had a RX8 running the zex 82021 system. "That is a wet system"
In my experiences Nitrous and ethanol don't mix. Even at a small 5 or 10 percent blend my car suffered massive intake backfires. Save your self some money in repairs and just get a 92 or 93 octane gas besides e85 might be cheaper and yes ethanol does raise the octane level, but it will have worse mileage and possible intake backfires or worse.
Just my 2 cents, and if the gas station is running a ethanol blend as long as its under 10 percent they don't legally have to post it on the pumps.
Chris
doctorpullit
Apr 23, 2017 05:35 AM
captchaos
Mar 15, 2016 12:18 PM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 19, 2015 01:07 AM
