Upgrading fuel pump on returnless system
Old Feb 11, 2009 | 08:25 AM
KRRZ350's Avatar
What's the deal for 5.5 gen and altima guys who want to run big shots & need to upgrade their fuel-pump. Any options out there? I'm trying to direct an se-r customer in the right direction for running a 150 progressive, and I don't know what you guys think but the stock pump seems sketchy to me in that range, and with the whole in-tank regulator setup that throws a curveball in the mix no?
Old Feb 11, 2009 | 09:40 AM
accordingtou's Avatar
VQ30 DE T
It should not be a problem.. Drop a walboro in the tank & run a fpr @ the fuel rail.
Old Feb 11, 2009 | 08:57 PM
tonedef's Avatar
yeah, i dont know if thats me kevin but i am trying to figure this out.
there is not fuel pump directly for the 05-06 altima, was thinking a 255 but i dont know how to go about wiring it.
i had purchased a dual stage kit but the guy installing it convinced me to go single, also the guys on nissan club. my idea was to run a 50 shot second and a 100 maybe progressively in third.
i just bought the NOS mini two stage progressive controller.
i was reading jimes article on his site earlier about the NX kit that u dont even have to change jets, sounds sweet. now since i just have a single stage i am wondering if i can still spray two stages with my 2 stage controller but i guess i will need two more solenoids. the guy installing this thought i was crazy.
so for now thinking of reordering the two stage conversion
any help with this is appreciated
as for a fuel pump solution
and what is the use of the fuel pressure regulator?
i do have a fuel safety cut off
Old Feb 12, 2009 | 06:48 AM
t6378tp's Avatar
Turbo 3.5
to run 2 stages you wil need a total of 4 niods and 2 nozzles
and the afpr is used to bring fuel psi back down when you install the walbro
Old Feb 12, 2009 | 07:03 PM
tonedef's Avatar
bump
and would a FPR that is universal and for a return hose style work??
i guess mine is returnless
Old Feb 13, 2009 | 01:28 AM
AceofSpds's Avatar
wat
Originally Posted by tonedef
bump
Im pretty sure i remember reading somewhere how aeromotive fpr's work on returnless setups. I think synapse also.
Old Feb 13, 2009 | 07:47 AM
tonedef's Avatar
thanks
Old Mar 9, 2009 | 02:55 AM
raptor1234's Avatar
Yes it would work .. have you tried it yet??
Old Mar 9, 2009 | 04:14 PM
tonedef's Avatar
havent yet
Old Mar 15, 2009 | 08:22 PM
tonedef's Avatar
still havent found a solution, i am thinking of sticking with the stock fuel pump and just going to convert to return style whenever i decide to go down the path of boost
BkGreen97
Apr 2, 2016 05:47 AM
bumpypickle
Sep 20, 2015 08:22 AM
