Waste Spark and Nitrous backfire
Old Nov 1, 2009 | 08:35 AM
streetzlegend's Avatar
Sup guys. Does anyone know if having Waste Spark ignition increase the chance of a nitrous backfire? (i have waste spark because i use the J&S).
Old Dec 29, 2009 | 01:04 PM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
I would assume not since the intake valves are closed during the exhaust stroke when the extra spark happens.
Old Dec 30, 2009 | 01:30 AM
krazy6's Avatar
Pretty sure that the ignition doesn't have anything to do with backfires.
A nitrous backfire is the result of fuel puddling in the intake/intake mani. Spraying too low in the rpm range can cause this.
Old Dec 30, 2009 | 05:17 AM
nismology's Avatar
Beside what has already been said nitrous isn't flammable on its own. Now if we had batch fuel injection there might be some reason for concern.
Old Dec 30, 2009 | 08:34 AM
It's highly likely that he's using a wet kit. That would mean there is both fuel and nitrous being injected.
Old Dec 31, 2009 | 11:16 AM
nismology's Avatar
Good point. But like you said, the extra spark occurs when the intake valves are still closed (late exhaust stroke) so there's no risk of something going wrong.
Old Dec 31, 2009 | 11:18 AM
Good point. But like you said, the extra spark occurs when the intake valves are still closed so there's no risk of something going wrong.
Agreed!
Old Jan 2, 2010 | 11:17 PM
I just saw these replies, sorry was in chicago for a week. So yea, after doing some reading and thinking i concluded that I shouldnt have issues with waste spark and nitrous, and yea it would be a wet kit. For now im going to hold off on the nitrous, instead I am putting in a bigger turbo I got, so it should take care of my HP goals. (my current turbo is maxed out)
Old Jan 5, 2010 | 10:19 PM
Cynthiya's Avatar
Do NOT use a waste-spark system in your application. I would be suspicious of waste spark with an intake system under pressure and completely filled with explosive mixture. Think of your intake with NOx and fuel to be a pipe-bomb, sitting next to an ignition source.
Old Jan 6, 2010 | 09:11 AM
Exactly the reason for my post, 15 lbs (my boost) of pressurized nitrous, fuel, air, and methanol is probably good enough to take out a small building.....
Old Jan 6, 2010 | 10:08 AM
What chance does it have of causing any issues when the intake valves are closed, though? I'd be more worried about heat igniting it.
Old Jan 6, 2010 | 01:09 PM
Well the chances should be slim to none, unless the valves are leaking or something, or rev limiter hit. Either way, I have determined if I do go with nitrous, its going to be a dry shot, 50hp or less, no higher.
Need help
23
Oct 2, 2015 08:56 AM
Gingerheadman
Oct 1, 2015 05:11 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
