Fuel pressure regulator
Old Jan 10, 2010 | 03:50 PM
Revs2Hard's Avatar
BARF
Hey guys I was wondering what what in line fuel pressure regulator your running? Im going up to a 100 shot from my 75 and i wanna raise my fuel pressure. Im thinking 10lbs is just about right, but I would like your opinion too. What fuel pressure, pumps, injectors etc... are you guys running and what shot?
Old Jan 10, 2010 | 04:53 PM
t6378tp's Avatar
Turbo 3.5
why would you want to run higher fuel psi, just get a walbro 255 and tune with the jets
Old Jan 10, 2010 | 07:12 PM
Revs2Hard's Avatar
BARF
Well, I was asking because with the 100 shot jets I'm worried about leaning out. I already have the 255 walbro, I just didnt know if adjusting it with the jets was enough.
What clutch are you running? My exedy is already going out, but thats most likly from auto cross.
Old Jan 11, 2010 | 03:55 AM
t6378tp's Avatar
Turbo 3.5
I had a rps clutch but it was too stiff and went with a act 6puck with a hd psi plate
Old Jan 11, 2010 | 10:44 AM
Revs2Hard's Avatar
BARF
How much did that cost you? Also I just bought the new ZEX spark plugs have you used those? I figured there 31.45 for the set so why not give um a try.
Old Jan 11, 2010 | 12:44 PM
MoncefA33's Avatar
If you're running a wet kit you shouldn't have an issue as long as you have the right fuel jetting.
Are the ZEX spark plugs 1-step colder than stock?
Old Jan 11, 2010 | 01:01 PM
secondtonone317's Avatar
nycnissans
no need to raise FP
if anything wideband and play with jets
AFAIK nitrous is somewhat a stand alone power adder.........you add fuel jet and nitrous jet and you're good. I know there's more to it but thats the basics the way I see it.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
