Two races left this year, had to try for a 11.99 to run Semi-Pro
Aug 2, 2012 | 03:08 PM
With 2 races left I decided to try and run the Semi-Pro class (11.99) and quicker. I am back to a stock engine after blowing the last one up trying out a 200 shot on the highway when the fuel solenoid froze. This happened the fall of 2010 so I raced all last year and this season N/A. So thinking ahead, I want to run Semi-pro with the G35, I decided to try the spray again to see if I could hit the 11.99 mark without hitting it with too big a shot. So I tuned it with a 75 shot on the methanol and went to the track last night to test.
N/A is now in the 13.2 range without cams, SSIM, V-Manage etc. 1st run at 22 deg timing netted a 12.116 @ 112 mph 1.73 60' so I knew I was in the ballpark. Did 3 more runs and upped the timing to 26 deg and 11.9's appeared. Best was a 11.974 and a 60' of 1.721. I do have another 75 shot 2nd stage on the cruise control button if required but I didn't exercise the option. I'll save that for the race next weekend. Not bad for a stock block with only headers and stock suspension as well. I really like the methanol vs race gas, you can get it anywhere, its cheap and my washer bottle is my race gas fuel cell.
Aug 3, 2012 | 04:48 AM
You cut better 60' than half of my friends with RWD cars.
My buddy has a 640whp turbo mustang on a 28" drag radial and he only cuts 1.8's.
Impressive.
Aug 3, 2012 | 05:27 AM
Impressive.
You know whats even funnier? I did one launch in 2nd by mistake and it did a 1.86, N/A runs were high 1.9's and low 2.0's.
Aug 3, 2012 | 08:50 AM
Quote: You know whats even funnier? I did one launch in 2nd by mistake and it did a 1.86, N/A runs were high 1.9's and low 2.0's.
A 75 shot launch starting in 2nd gear? I'm glad nothing broke by spraying at 2000rpm.
Good luck with the last two races. I hope you get the car dialed in. Is it bracket racing or an 11.99 index race?
Aug 3, 2012 | 10:26 PM
Awesome Jime, what stall converter are you using for these runs? I am prepping my car to spray off the line (might just spray the whole 1/4 on top of the 15psi+methanol). I am going with a 50shot which should spool the turbo in 1st gear almost instantly to 15psi (hopping to get similar 60's)
Also, quick fact, if you go to a parts store and get bottles of Heet (yellow bottle), its 99% methanol =) iv been using that as my meth for a few years now. lol.
Side question, what nozzle size/pump pressure are you using in meth to make up for the 75shot?
Aug 4, 2012 | 03:54 AM
Quote: A 75 shot launch starting in 2nd gear? I'm glad nothing broke by spraying at 2000rpm.
Its 11.99 and quicker bracket. Next weekend is my second last race, two day $1200 for win each day in semi-pro and $800 for sportsman so I double enter.
Aug 4, 2012 | 04:02 AM
Quote: Awesome Jime, what stall converter are you using for these runs? I am prepping my car to spray off the line (might just spray the whole 1/4 on top of the 15psi+methanol). I am going with a 50shot which should spool the turbo in 1st gear almost instantly to 15psi (hopping to get similar 60's)
Stock converter my edge racing one stripped a bolt a while back.
I buy 1 gal jugs of methanol 99% for $10 and run it undiluted.
I will have to check my chart when I get home for the jet sizes, we are at a family reunion this weekend. Pump pressure is around 150 psi. Fuel jet is around 50% larger than stock.
Aug 4, 2012 | 10:50 AM
Impressive as always. I bet you get the strangest looks at the track.
Aug 23, 2012 | 12:22 PM
Nice passes
Nov 27, 2012 | 12:37 AM
This man could use a GoPro camera, reminds me of those Be a Hero videos.
