View Poll Results: Which battery?
OEM
14.29%
Costco
13.10%
Optima Yellow Top
19.05%
Optima Red Top
29.17%
Other
24.40%
Voters: 168. You may not vote on this poll
Battery Replacement
Old May 28, 2007 | 12:31 AM
  #41
CannaBis's Avatar
12-twenty packs of Duracell AA's.
Haha, I have an OEM battery but considering a new one.
Old May 29, 2007 | 12:58 PM
  #42
largestal's Avatar
Donating Maxima.org Member
Optima yellow here. Never again. Too much money for only a mid-perfomer of a battery. They do look good but I think they should last longer than 3 years. Probably going to go Duralast as they have worked well in my motorhome.
Old May 29, 2007 | 06:59 PM
  #43
bwinter7's Avatar
[QUOTE=CannaBis]12-twenty packs of Duracell AA's. [QUOTE]
Whoa buddy, be careful with all that current, you'll set the car on fire lol
Old May 29, 2007 | 09:09 PM
  #44
Suzie (v)Q's Avatar
Fast & Furry-ous
Originally Posted by CaTalyst.X
Interstate battery would be the best choice if you dont have a system. They last forever, start everytime.
Interstates have served me best over the years through Chicagoland winters, reasonable sound systems, occasional deep cycles, and even a roll-over accident.
/serious
300amps should be plenty for the summer....well, at least until they pop.
Try NIMH instead.
___
JLD
Old Jun 13, 2007 | 05:56 PM
  #45
hogey228's Avatar
Battery finally died today
Of course the battery dies when I need to get to work this morning. So after some more research (ConsumerReports.org) I was thinking of going with the EverStart Maxx (Wal-Mart Brand) which has a 36/108 warranty and 700CCA.
Does anyone have any experience with this brand?
Old Jun 14, 2007 | 09:51 AM
  #46
bigEL's Avatar
Originally Posted by mtl-maximus
The original battery on my 2k Max lasted for 7 yrs.
Last winter had some issues starting the car at -25C so I went and changed at the stealership. I'll see how good the new one is...
5+ yrs on mine. I also had a couple slow cranks two winters ago, but I just plugged in the trickle charger overnight and it cured the problem. The only reason I won't do OEM again is because they aren't the maintenance-free kind. I always had to check the levels and make sure I topped off with distilled water. There's no excuse for batteries like that these days. Everything else on the market is and has been mainenance-free for years and there is no cost difference.
Old Jun 14, 2007 | 02:09 PM
  #47
DONS459's Avatar
I picked up an Everstart from Wal-Mart last July for my 97 grand prix, The dual connector one and its been great so far as it should be. Fresh too, Was made a month earlier.
Old Jun 14, 2007 | 03:53 PM
  #48
00MaxSE's Avatar
Pointy Elbows
Bought one of those for my truck a few years back. Very good for the price.
Old Jun 14, 2007 | 11:36 PM
  #49
SilverGLE's Avatar
I'm watching you, boy...
Agreed. Had one in my last car (94 Camry). Cheapest battery and had better CA/CCA than the auto store brands.
Old Jun 15, 2007 | 10:31 AM
  #50
JimmyH's Avatar
7 years 166000 miles on my oem non-maintenence free battery. Keep filling them with water and lube the terminals and they will outlast 20 "maintenence-free" batteries.
Old Jun 15, 2007 | 01:32 PM
  #51
00MaxSE's Avatar
Pointy Elbows
Old Jul 1, 2007 | 04:37 PM
  #52
select127's Avatar
Originally Posted by Torgus
at full tilt i'm running 2000w RMS of a possible 2400. i dim alot. sucks...any suggestions are welcome. i have hifonics diamond and kicker for amps which are all decent brands. as i stated above i'll do the big 3 and throw a redtop in my bay and move my current batt to the trunk. if that doesn't fix it yellowtop in the trunk + my current batt.
why dont you keep your current bat under the hood and throw the redtop in the trunk? and anyone got pics of their big 3 set up? i recently installed a yellowtop and got a few questions. do i run my big 3 wire parallel to the stock wire or upgrade the stock wire? i also noticed that my bat. is grounded the same place as the engine block, it also seems like it's the same wire running from bat. to ground and then to block so can someone confirm this? it was dark when i installed the yellowtop so couldn't really tell.
Old Jul 1, 2007 | 11:12 PM
  #53
2K2Beast's Avatar
Just go with the Optima Yellow top and never have to worry about it, thats how i see it!
Old Jul 2, 2007 | 11:15 AM
  #54
Froggmann's Avatar
In my max the dealer stuck in a Honda Battery, seriously that's what it says on the side. But in my Bronco I have a red top. I've had it for I think a little under 2.5 years and it just works. Even when it is low it will still start the 351 under the hood. I also put it through it's paces, when I got it I only had a 95 amp alt. Even with only that it powered a set of 2nd gen max fans for cooling, a 1500 watt amp that powered 2 12s, a 200 watt head unit, 2 Hella 500s, fogs and of course the standard headlights. If that doesn't put a load on the battey I don't know what will. Oh and never a drainage issue. Since then I have upgraded to a 130 amp alt, bigger charge wire, removed the fogs (one of them is grounding internally) and changed the fan to that of a lincon mark VIII (Single fan). I can leave the truck sitting for more than a week and that battery will still hit the starter as hard as ever.
Oh and I voted yellow top, that way if or when you decide to upgrade your electronics you will have a battery that will allow them to run long after the engine is off.
Oh and the great thing about the optimas, they don't get post corosion. I used to have to clean the posts of my lead-acid batterys once every month or so, since installing the red I never have had to clean it. In fact the only time I even look at the battery is when I'm jumping other vehicles with it.
Old Jul 2, 2007 | 12:45 PM
  #55
Trurida18's Avatar
[QUOTE=bwinter7][QUOTE=CannaBis]12-twenty packs of Duracell AA's.
LMAO!!!
Old Jul 2, 2007 | 12:49 PM
  #56
Trurida18's Avatar
Old Jul 2, 2007 | 02:24 PM
  #57
charr82's Avatar
This is the battery I went with recently. My OEM lasted about 4 years and 186,000 miles. The EverStart Maxx has an excellent warranty, cheap price, and is made by Johnson Controls. I had them test mine before I bought it and it tested at 780CCA even though it is rated for 700CCA. It should be good for a long time.
Old Jul 2, 2007 | 02:35 PM
  #58
00MaxSE's Avatar
Pointy Elbows
You have 186k on your '03??
Old Jul 2, 2007 | 04:12 PM
  #59
charr82's Avatar
Yeah, she's been on the road alot....
Looks, runs, and drives great. Can't complain.
All original too (knock on wood)
Old Jul 2, 2007 | 05:43 PM
  #60
00MaxSE's Avatar
Pointy Elbows
Simply amazing!
Old Jul 3, 2007 | 11:38 AM
  #61
since71's Avatar
Go Diehard gold.
Old Jul 3, 2007 | 10:30 PM
  #62
bigEL's Avatar
Good to hear that someone has a trouble free Maxima.
Old Jul 4, 2007 | 07:33 AM
  #63
machinehead131's Avatar
186k holy cow, thats a lot. Curious to see how long it lasts. Are you auto or 6 speed? Same clutch if 6 speed?
Old Jul 4, 2007 | 08:01 AM
  #64
charr82's Avatar
Autotragic. I hope it lasts a long time to come. I think it will. I am sure I'll have to replace the transmission at some point if I keep it long enough, but for now it shows no signs dying anytime soon.
Anyway...we should probably let this thread get back on topic.
Old Aug 1, 2007 | 09:52 AM
  #65
Trurida18's Avatar
LOL, that is something.....in just 4 years!
Old Aug 9, 2007 | 11:56 PM
  #66
MillionBlades's Avatar
My local nissan shop told me that its $100 for a new OEM battery. Should I go with Interstate or Gold/Platinum Start?
Old Aug 10, 2007 | 12:16 AM
  #67
Suzie (v)Q's Avatar
Fast & Furry-ous
For me...
$100 for a battery made by "some company" who can at least manage to make a battery to Nissan's standards.....
OR...
$60-80 for an Interstate battery; you know the manufacturer, and it's less.
ALTHOUGH...
I'm an Interstate guy, I'll always trust 'em; but it's still cheaper.
That's the info from me; What info do you have to offer? Big stereo or other high drain devies? If you have them, do you run them for long without the car running?... etc. What's your needs?
___
JLD
Old Aug 10, 2007 | 12:17 AM
  #68
spdfreak's Avatar
I went with the Costco battery since it has a great warranty.
I didn't need a light battery for racing so th Costco one suits me best, and best for the price.
Old Aug 16, 2007 | 02:08 PM
  #69
Torgus's Avatar
i just payed 42 $ at walmart. 865cca. before i was going to get a redtop and a yellow...for the price i can buy 3 of these...for every one optima
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
