Hi idle issue
Old May 7, 2016 | 11:10 AM
blkmax1's Avatar
Hi idle issue
Ok got the car up and running... On start up im getting a blue cloud of smoke then it tapers off. After it warms up it idles around 1k, but after driving for a while it idles between 1500-2000 rpms. Once it even stayed at 3000rpms. I have a check engine light but the only code is an o2 sensor. I also find that when braking it feels like the engine is fighting against stopping the car.
Old May 7, 2016 | 02:17 PM
MadMax SE's Avatar
It is almost guarantee to be your IACV. Does it bounce from 1.5k to 2k rpm?. Standard idle is about 650. I would blip the throttle very lightly and it would rev to about 2k by its self
Old May 8, 2016 | 05:17 PM
vqmaximus30's Avatar
Go off on a limb and inspect the o2 senor that you have the code (look for oil residue, heavy carbon build-up, and damages of course). Also the blue smoke is burnt oil either coming from your piston rings failing or valve covers leaking badly enough to taint the exhaust manifold gasket and seep into your exhaust. Also check transmission fluid. If all checks out good then inspect the idle air control valve by removal (Google search for iacv location if need be). Check for coolant, heavy carbon buil-up, and if you have a volt ohm meter check resistance.
Old May 10, 2016 | 07:04 AM
blkmax1's Avatar
Ok. I will. I see that i might need valve cover gaskets. Do you think cleaning the valve will help or should i just replace. Being that it doesnt throw a code for the iacv doez it mean my ecu is still fine? Im not sure how long the car has had driveability issues. Thanks for all advice
Old May 10, 2016 | 07:09 AM
blkmax1's Avatar
Havent cleaned it yet...<br/>
Old May 10, 2016 | 07:23 AM
blkmax1's Avatar
I Tried to take a video but i cant load it. To show how the rpms jump after even a short drive. If i start it up and let it idle it stays at about 1100 rpms then may jump to 2000 slowly after a while
Old May 10, 2016 | 07:24 AM
cornholio's Avatar
Only way to know is to open it up and check
Old May 10, 2016 | 07:03 PM
What o2 sensor are you getting the code for? If it is bank 1 sensor 1 or bank 2 sensor 1 it will cause a lot of problems. Also did you inspect the iacv? Based on what you find when you inspect the iacv will determine whether or not cleaning it will help. Does it idle badly on start-up or after it warms up?
Old May 13, 2016 | 11:44 AM
blkmax1's Avatar
It idles bad after it warms up. Im thinking about getting a warpspeed ypipe and replace iacv. Im thinking i might just look for a low mileage motor and call it a day. Replace all components while its out
Old May 13, 2016 | 11:49 AM
DEK's are solid, stay with the IACV inspection method until then.
Old May 13, 2016 | 01:18 PM
blkmax1's Avatar
Cool definitely... I only want a low mileage motor is because of the blue smoke on start up... rings worn
Old May 13, 2016 | 02:26 PM
Go to auto zone, advance auto, etc. get them to check the engine code. If one of your o2 sensors is bad especially any sensor 1 location it will cause problems when the car is warmed up. Also inspect the iavc. I agree with you on getting headers as long as the engine isn't screwed, aka leaky rings.
Old May 13, 2016 | 02:30 PM
Yeah I forgot about that part.
Old May 13, 2016 | 02:36 PM
Let us not assume the rings are bad though, for the sake of a diy'er remove the plugs and inspect for burnt oil or fresh oil for that matter. Also inspect the tube that leads to the spark plug hole and make sure the tube seals are not leaking down onto your spark plug.
Old May 13, 2016 | 05:21 PM
blkmax1's Avatar
Your right i didnt check the plugs, hopefully the spark plug tubes are bad which is causing the blue exhaust fumes
Old May 14, 2016 | 03:43 AM
MadMax SE's Avatar
If the tubes aernt the issue then mabye the rings are just sticking and loss their springness.The mess left behind could make the rings sticky. What weight oil do you use? If you have no choicd but to drive it i would use a slightly thicker oil then use 2 stroke tcw3 in the gas to help lube the top end and kill potentialy ring sticking carbon build up. Others have said running tcw3 will burn less oil. how much oil do you burn? Ive read a lot of threads about sticking rings and how it can be helped.
Old May 15, 2016 | 08:50 AM
bootsybuns718's Avatar
I Had same issue happened to be my EGR, Took it apart cleaned it an used some Seafoam, Oddly I didnt get a MiL code for Egr either.
jj9711
Jun 30, 2016 12:56 PM
gwmac
Mar 12, 2016 06:55 AM
ShunDoe
45
Mar 8, 2016 07:52 PM
slickblack94
Feb 29, 2016 10:33 AM
sebastian2041
Feb 21, 2016 09:50 AM
