$400 For An 0302 Code Fix?!!
Old Nov 25, 2003 | 12:21 PM
Turbobink's Avatar
My dealer just called me back and says they need to drop a frame member to access the EGR tubes for cleaning to remedy my CEL... Cost? ~$400.00.
I was anticipating about $150.00 but not $400.00!.
Old Nov 25, 2003 | 12:34 PM
slowmanvns's Avatar
That's a bunch of crap...they can get to it by removing the air filter and a few other upper parts. I changed mine and the hardest part was removing the nut that connects to the EGR itself. Before you replace it check to see if the small rubber hose connected to the EGR valve has not come loose at either end. The valve costs about $133 from the dealer and should only take about 45 mins to replace.
Old Nov 25, 2003 | 01:20 PM
Jatan's Avatar
That's why it's called the stealership
Old Nov 25, 2003 | 02:29 PM
deezo's Avatar
Tell them not to do the work. They're full of it.
Old Nov 25, 2003 | 03:07 PM
Kevlo911's Avatar
Kevlo for President
0302
Diagnostic Trouble code 0302 points to a problem with the Exhaust Gas Recirculation system. The malfunction is detected by the Engine Control Module when no EGR flow is detected under conditions which call for EGR. Possible causes include:
- The electrical harness or connectors (valve circuit open or shorted)
- The EGR valve is stuck closed
- Weak or dead battery
- The EGR passage is clogged
- Faulty EGR temperature sensor circuit
- A leak somewhere in the exhaust system
The EGR Volume Control Valve may be tested with an ohmmeter. Disconnect the electrical connector. Looking at the connector half which is attached to the EGRVCV with the latch at the 12 o'clock position you will see two rows of three terminals. The top row is numbered 1-3, right to left. The bottom row is numbered 4-6, right to left. Measure the resistance between these terminal pairs:
2 1
2 3
5 4
5 6
... all resistance values should be 20.9-23.1 ohms at 68 degrees F.
Reconnect the EGRVCV connector halves. Turn the ignition switch ON OFF repeatedly. Verify that the EGRVCV shaft moves smoothly forward backward according to the ignition switch position.
The Exhaust Gas Temperature Sensor may be tested with an ohmmeter. The specifications are ...
- at 32 degrees F, 0.68-1.11 Megohms
- at 122 degrees F, 0.09-0.12 Megohms
- at 212 degrees F, 0.017-0.024 Megohms
that might help
Old Nov 25, 2003 | 05:32 PM
MAXTOUT's Avatar
What are the symtoms with a faulty EGR system?
I have had problems with starting the past few days and when I finally got it started there was what looked and smelled like exhaust coming from around the throttle body. It seems to be starting and running fine now that I finally did get it started.
Old Nov 25, 2003 | 07:19 PM
Frank Fontaine's Avatar
The price is correct. The procedure may have been described wrong. As you know, management rarely knows how to do the technical work themselves, so they are trying to describe the procedure having never performed it firsthand. This principle applies whether it's law, physics, engineering, plumbing, snowthrowing, whatever.
hez8813
Mar 12, 2020 12:06 AM
220k+ A32
Sep 22, 2015 03:08 PM
jchronis2552
Sep 21, 2015 05:52 AM
Steven Orozco
Sep 12, 2015 10:41 PM
