S-AFC or something else??
Old Dec 4, 2002 | 07:34 PM
RBa's Avatar
RBa
Question about the S-AFC???
How do I get around the 5thgen ECU???
Old Dec 4, 2002 | 10:31 PM
BigDogJonx's Avatar
S-AFC. That is the best way. I dont know of any other way to manipulate the ECU on readings of the MAF.
Old Dec 5, 2002 | 07:39 AM
mtrai760's Avatar
'Trynna' is not a word
Fields AFC is better...
Why? 3 different settings, Apexi only has 1
Old Dec 5, 2002 | 07:55 AM
PCGuRu2K's Avatar
Re: Question about the S-AFC???
There are someone settings you need to setup. Low39% High 40% and the ecu won't reset.. I'll send you my doc that I put together later when I'm home..
Old Dec 5, 2002 | 05:30 PM
JAY25's Avatar
Fields is better if your running Nitrous and supercharger or Nitrous period. If that was the case I would have bought the Fields. The fields is a lot smaller for a nice custom fit. SAFC will do the job to tune air/fuel ratio with just a plain supercharger.
Old Dec 8, 2002 | 10:05 PM
RBa's Avatar
RBa
Re: Re: Question about the S-AFC???
No Doc yet..
Old Dec 9, 2002 | 05:07 AM
PCGuRu2K's Avatar
Re: Re: Re: Question about the S-AFC???
No Doc yet..
What's you email addy.. shoot me a pm..
Old Dec 9, 2002 | 01:30 PM
ToYLeT902's Avatar
JET Speed Lab
Originally posted by JAY25
how much does the fields go for?
Old Dec 9, 2002 | 01:41 PM
JAY25's Avatar
About the same price $300 some where around there. I paid $290 for my SAFC.
Old Dec 9, 2002 | 02:13 PM
SuDZ's Avatar
So you can have one setting for like NA and then the other for when your on the bottle? That is kind of cool.
SuDZ
Old Dec 9, 2002 | 02:20 PM
BigDogJonx's Avatar
SuDZ
True, but most always an S-AFC will do nothing for an NA car. But I get your point on how you can have all the settings to zero when you NA and then set to what your bottled settings are. But then again this is very hard to use on a bottle cause if you spray at different rpm levels it throws off the whole SFC. I always though this SFC is more geared towards forced air not juice.
Cause if you use it with juice, you have to remember to change the settings everytime you juice and on top of that juice at the same RPM level everytime to ensure you get the best hp possible.
Dixit
Old Dec 9, 2002 | 02:29 PM
ToYLeT902's Avatar
JET Speed Lab
Dixit
so if you had juice, you shouldnt bother with all these things?
Old Dec 9, 2002 | 02:32 PM
JAY25's Avatar
the fields is great if you want to tune your Juicy ride
Old Dec 9, 2002 | 02:33 PM
SuDZ's Avatar
Sounds it from his post.
SuDZ
Old Dec 9, 2002 | 02:36 PM
SuDZ's Avatar
Dixit
SuDZ
Old Dec 9, 2002 | 02:40 PM
ToYLeT902's Avatar
JET Speed Lab
hmm, so what u do is, get the fields, go to the dyno with a full bottle, tune ur car...
then when u want to run with the bottle, turn the fields on?
otherwise ur car will run "stock"?
i am a lil
Old Dec 9, 2002 | 02:48 PM
BigDogJonx's Avatar
My bad on posting twice, dont know how that happened.
I aint say no point in using it. If you read it I said it needs to be used correctly to work. Like I said, lets say you always juice at 3k rpms. And one of your settings on the S-AFC is at 3k and adjusted the a/f ratio according.
Now lets say the next time you activate the boost bottle, and then also change over to the your boosted setting on your controller, well lets say this time you boost at 4krpms, this will throw off the 3k-4k rpm range on a/f which might hurt your Whp dramatically for that moment till you spray.
I did not say the controller is worthless for juice, just a bit more work and things to remember to do like turning it to the correct setting and off when not in use and all that other jazz.
Dixit
Old Dec 9, 2002 | 02:50 PM
BigDogJonx's Avatar
i am a lil
Yeap. That would be perfect. When you want to spray you turn on both the bottle and the fields and then you spray. If not spraying and chilling keep the fields off or to the N/A setting that you may have dyno tuned. But as I said earlier, if you want to dyno tune the a/f on a N/A car, you wont be doing much. Probably wont make a difference.
Dixit
Old Dec 9, 2002 | 02:58 PM
JAY25's Avatar
i am a lil
I dont know much about the N2O dept. Tony can help you with your answers or Mardigrasmax. I am not spraying but I know Matt was spraying and he has a different setting for track and regular everyday ride since he tuned his car on the dyno.
Old Dec 9, 2002 | 03:03 PM
SuDZ's Avatar
Never looks like more than a 2-3 HP gain when I see them reviewed in magazines.
SuDZ
Old Dec 14, 2002 | 02:42 PM
RBa's Avatar
RBa
SuDZ
This is the S/C-turbo forum.. Take the NOS questions to the nitrous forum..
BippuBenji
Sep 9, 2011 10:39 PM
BippuBenji
Mar 12, 2003 10:41 PM
LatinMax
Feb 18, 2003 03:49 AM
mtrai760
Jun 30, 2002 12:29 PM
