What kind of T-fitting did you use for the Boost Gauge?
Old Dec 24, 2002 | 12:17 PM
BlackCat's Avatar
RIP '98 Maxima SE
I called up my local car parts shop and they only have them in plastic. Will that work with the brass Autometer adapter or should I find some place that has brass ones?
Old Dec 24, 2002 | 12:37 PM
delio's Avatar
Re: What kind of T-fitting did you use for the Boost Gauge?
What do you mean brass Autometer adapter... it has been a while since I saw an autometer boost guage in the box.
Old Dec 24, 2002 | 12:39 PM
RBa's Avatar
RBa
Home Depot carries a whole line of em.. Check out the plumbing section.. Used a 3/16in fitting and a plastic Tee......
Old Dec 24, 2002 | 12:48 PM
BlackCat's Avatar
RIP '98 Maxima SE
Re: Re: What kind of T-fitting did you use for the Boost Gauge?
The T-fitting connection is on the far left...
http://images.cardomain.com/installs...57_18_full.jpg
Old Dec 25, 2002 | 01:17 AM
iansw's Avatar
I've got an Autometer gauge and am using a plastic fitting.
Then again, my vacuum has always shown as low - maybe I'll try a brass fitting and see what I get.
Old Dec 25, 2002 | 09:07 PM
BlackCat's Avatar
RIP '98 Maxima SE
Which hose did you put the t-fitting on? I put it on the hose going to the Hobbs switch. Is that ok?
Old Dec 25, 2002 | 10:55 PM
iansw's Avatar
Better to go off the manifold - T into the hose right behind the TB - there are 2 ports right there to tap into.
I circled it in the pic (The pic is of the MEVI, but the ports are in the same place)
IanS
Old Dec 26, 2002 | 09:37 AM
BlackCat's Avatar
RIP '98 Maxima SE
IanS
Thanks Ian!
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
magiconthetire
Oct 26, 2015 09:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
