buying supercharger, have a couple questions
Old Dec 25, 2002 | 11:03 AM
97MaximaGLE's Avatar
Iam going to buy a v2 soon. iam a 97 gle so that means auto. Iam going to upgrade my tranny with a rebuild and the works in the future when my stock one starts to go. anyways, i was going to run the 3.33 pulley to start out with? good idea? what FMU do I need running this? also should I go one step colder plugs? I work at a ford dealership, hehe Iam having a tech from work help me install it I want to beable to say I did most of it or know what to fix if I got a problem down the road. I was going to run 2 guages boost,EGT,. Any info is appricated. my private messages dont work so reply on here otherwise email me at
mycerwinvegas@aol.com
Old Dec 25, 2002 | 02:38 PM
BigDogJonx's Avatar
Might want to search on the FMU, I cant be sure since Im a 5th gen and I know it shouldnt matter but I think you might want a 8:1 FMU disc. You definetely want one step colder plugs.
Any reason why you are going with a 3.33" pulley? Only reason I ask is because a few people who have gone with it seem to think they got nothing from it and recommeded going to 3.25 or 3.125" But its upto you.
As far as your tranny and doing the work after it falls apart, to ensure it dont fall apart in 2weeks, get at least the Valve Body upgrade performed and at least a tranny cooler.
On your Private messages, is your box full? if so delete all the messages in your inbox and SENT folder and you will be alright.
Dixit
Old Dec 25, 2002 | 03:13 PM
maybe I should go right to the 3.125 what about grinding to make it fit?? what a running to rich?? what FMU? any help is appriciated.
Old Dec 25, 2002 | 03:40 PM
BigDogJonx's Avatar
http://forums.maxima.org/showthread.php?threadid=165054
That will help on your grinding issue.
You wont have an issue with running rich or lean on the 8:1 FMU disc with the 3.125". You might want to get an S-AFC to further dyno tune it get the best a/f ratio and the most HP possible.
Dixit
Old Dec 25, 2002 | 06:11 PM
delio's Avatar
PJ,
Go with the 3.25 and keep the 6:1 disk...if you go lower than 3.25 you will need the 8:1
Old Dec 25, 2002 | 07:59 PM
JAY25's Avatar
Originally posted by delio
PJ,
The new V2 kits are coming with 8:1 FMU disks directly from stillen. Just giving you guys heads up.
Old Dec 25, 2002 | 08:15 PM
Tanman's Avatar
What size FMU disk did the old V2s come with? I've heard different answers, but I thought it was 12:1.
Old Dec 28, 2002 | 01:18 AM
96shogunmax's Avatar
I have an extra 8:1 if anybody wants ill sell.
I would say go with the 3.25 pulley and 8:1 disk. I am running 9-10 psi. 96 GLE auto.
Old Dec 28, 2002 | 07:45 PM
Tanman's Avatar
How much for the 8:1 disk? I suppose this will work ok with the 3.125 pulley?
Old Dec 28, 2002 | 09:13 PM
BigDogJonx's Avatar
That is perfect for a 3.125" pulley
Old Dec 28, 2002 | 09:22 PM
Tanman's Avatar
Sweeet, now I need the pulley and a price on this disk .
Old Dec 28, 2002 | 09:26 PM
BigDogJonx's Avatar
Pulley is like $60 at vortech and the disc alone at vortech $30. If you get the disc for $10 you are set.
Dixit
Tanman's Avatar
Is this the complete recalibration kit, or just the disk? Do you need the complete kit or can you use just the disk with existing FMU parts?
Old Dec 28, 2002 | 09:33 PM
BigDogJonx's Avatar
Im gonna say it is going to be just the disc. The washer looking deal. The whole kit usually has the FMU gasket and the ring that holds up the 8:1 disc. if you have a 6:1, then the ring that holds up the 6:1 will also hold up the 8:1. Just need to make sure the gasket is still good and not brittle and falling apart after you open it up.
Funny thing is the single recalibration kits are $30, and the full one is $45. And its like why not to get the full one cause it includes 5 other discs.
Dixit
Old Dec 28, 2002 | 10:15 PM
Tanman's Avatar
Dixit
Does the stock FMU come with 6:1 disk? Because if it does, then I can use the ring. Otherwise it'd be better to get the kit direct from Vortech.
Old Dec 28, 2002 | 10:17 PM
BigDogJonx's Avatar
Heres the thhing, the stock one comes with a 6:1 or a 8:1. I somehow got a 8:1 and few others got an 8:1. You should be fine.
Dixit
Old Dec 28, 2002 | 10:22 PM
Tanman's Avatar
Dixit
I always heard the stock came with a 12:1 disk. I guess this means I can buy the disk alone and use the stuff from the original FMU, except maybe the gasket. Hmmm... maybe better to buy the kit direct from Vortech.
Old Dec 28, 2002 | 11:50 PM
BigDogJonx's Avatar
Na, stock should be either 6:1 or 8:1.
Old Dec 29, 2002 | 11:16 AM
nymjayjay's Avatar
http://forums.maxima.org/showthread.php?threadid=177240
Jay from CT
FlaMark
Jan 8, 2016 07:21 AM
flu2000
22
Sep 2, 2015 07:29 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
soloist3
29
Sep 1, 2015 03:47 PM
