Crnk Pulley woes
Old Dec 29, 2002 | 09:29 PM
iansw's Avatar
Crank Pulley woes
Well, I've had this NASTY vibration when boosting for several weeks.
i think I figured it out - belt was too tight, lifting on the crank pulley and tweaking it - I loosened my belt, and it seems to be better, but not 100%.
I have a nasty oil leak (still drivable, but not 1 drop a week) behind the Crank.
Anyone else experienced vibration/oil leaks from the SC belt being too tight on the Crank Pulley?
IanS
Old Dec 29, 2002 | 10:12 PM
[maxi-overdose]'s Avatar
chebosto - sent in his SC due to oil leak. Vortech said the oil leak is due to belt over-tensioned.
http://forums.maxima.org/showthread....lt+AND+tension
Old Dec 30, 2002 | 07:23 AM
JAY25's Avatar
Re: Crank Pulley woes
IanS
If you have a impact you should be able to remove that 18 or 19MM bolt and replace the gasket behind the crank pulley to fix your leak.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
