Anyone install their own Fuel Pressure gauge?
Old Dec 30, 2002 | 03:51 AM
RBa's Avatar
RBa
I'm planning on installing my Autometer electrical fuel pressure gauge due to lack of funds and time.
I've already figured out which hose to tap into..
Just wanted to know how messy the job would be.. Should I prepare to be drenched in gasoline??
Old Dec 30, 2002 | 06:34 AM
Confused's Avatar
Permanent Maxima.org Resident
Re: Anyone install their own Fuel Pressure gauge?
depressurize the fuel system and have a couple of rags ready.. its not so bad.
Old Dec 30, 2002 | 07:08 AM
Sprint's Avatar
if you can change a fuel filter and fish wires for stereo.. you are in
Old Dec 30, 2002 | 07:26 PM
RBa's Avatar
RBa
How about a VB and an SC pulley??..
Old Dec 30, 2002 | 08:09 PM
[maxi-overdose]'s Avatar
5th gen fuel filter is in the tank
Old Dec 31, 2002 | 10:23 AM
Sprint's Avatar
o
sucks to be you guys
Old Jan 2, 2003 | 06:43 AM
Tanman's Avatar
You mean the pump or the filter?
RBa, why not squeeze off the lines so they don't leak fuel? Bend the line over itself and clamp both sides off, then cut in the middle.
Old Jan 2, 2003 | 10:02 PM
o
because our 5th gen bhp is above 200?
the filter....according to Haynes manual, 5th gen has an intergral fuel filter in the pump, located in the tank.
Old Jan 3, 2003 | 10:42 AM
RBa's Avatar
RBa
I was going to do that but I wanted to know how messy the job would be beforehand.. I dun wanna get drenched in gasoline.. LoL.
Thanks for the advice though..
Old Jan 3, 2003 | 11:03 AM
Tanman's Avatar
You're a braver modder than I am. I don't mess with anything that can kill me, which is pretty much everything .
Good luck with the install, do a write-up for those of us to follow.
Old Jan 3, 2003 | 02:21 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
just a related question...do you guys have any idea how or what kinda "T"/fitting I can use to mount/tap the fuel line to fit this pressure sender(its for oil pressure, but should work for fuel as wel)--->
I can't find a "T"/brass fittings at Home Depot that accepts the 1/8"NPT male end of the sender...any ideas??
Old Jan 3, 2003 | 04:17 PM
Tanman's Avatar
Re: Re: Anyone install their own Fuel Pressure gauge?
Maybe try an auto-parts store or summitracing.com.
Old Jan 6, 2003 | 11:42 AM
Stephen Max's Avatar
Pepboys has what you need.
Old Jan 10, 2003 | 07:06 AM
mayhem_J30's Avatar
Re: Re: Re: Anyone install their own Fuel Pressure gauge?
thanks this t-adapter thing is exactly the same problem i'm having with my fuel pressure gauge. wonder why it didn't come with the automer kit? btw, they're instructions aren't the best.
Old Jan 10, 2003 | 08:30 AM
XXXL Cracker's Avatar
DA-MAX -
I purchased my fitting through JEGS.com. I did not have any luck finding what I needed locally at any parts store.
The part is relatively inexpensive, maybe a dollar or two. Performance shops should carry or be able to order also!
D
Old Jan 10, 2003 | 09:14 AM
Originally posted by dlicari
DA-MAX -
D
Any good hardware or plumbing supply store will also have 1/8 NPT pipe Tees.
Cotozic
Jun 28, 2017 08:01 PM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
