Does the UDP effect SC
Old Jan 8, 2003 | 09:02 PM
LatinMax's Avatar
I am installing a SC this weekend or next week depending on when I get it shipped to me.
I know that the UDP gains HP by reducing the weight (85%) and diameter (15%) but will it lower or raise my boost on the SC?
If it lowers it. Who makes a pulley that is lighter but the same size?
Old Jan 8, 2003 | 10:22 PM
[maxi-overdose]'s Avatar
Re: Does the UDP effect SC
it will underboost your car....put the stock one back in.
Old Jan 9, 2003 | 04:51 AM
PCGuRu2K's Avatar
I had to take out my UDP when I put the blower in too... If your running the 3.33 pulley it'll be like your running a 3.6 with the udp on there
Old Jan 9, 2003 | 05:25 AM
Confused's Avatar
Permanent Maxima.org Resident
no one makes a lighter one in the oem size unless you have one custom made. thought about it but probably not worth the $.
Old Jan 9, 2003 | 09:19 AM
hacim105's Avatar
if you don't put your oem UDP back in you might screw up your car. When you get a supercharger usually all the pulleys get heavier.
Old Jan 9, 2003 | 09:37 AM
LatinMax's Avatar
Thanks for all the info. I have done some asking and so far no one makes a lighter OEM sized pully. But I will still look.
gavin68
Sep 18, 2021 12:36 PM
mclasser
22
Nov 12, 2020 01:58 PM
Dasmith
Sep 23, 2015 08:28 PM
