HELP~ the blet is running off the idler pulley~ HELP
Old Jan 12, 2003 | 01:19 AM
[maxi-overdose]'s Avatar
Hi all:
I finished the install of the belt tonight and I kept running into the same problem. The belt is running off the idler pulley towards the SC plate.
I noticed that the idler pulley wobbles when it is tightened on the plate. There are two washers for my idler pulley and I found out both of them are on the same site. Can that be the cause?
please help.
thx
Old Jan 12, 2003 | 02:38 AM
RBa's Avatar
RBa
Re: HELP~ the blet is running off the idler pulley~ HELP
Originally posted by [maxi-overdose]
Hi all:
please help.
thx
OH man.. You've been so helpful to me but I cant help you..
Someone post advice asap..
Old Jan 12, 2003 | 09:43 AM
Re: Re: HELP~ the blet is running off the idler pulley~ HELP
it's alright....I am going to try it again by replacing the washer. I will let you know how it goes.
Old Jan 12, 2003 | 10:20 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Hi all:
please help.
thx
How close is it to the SC plate?
Old Jan 12, 2003 | 11:02 AM
Chunger's Avatar
My other car is a Hybrid
The idler pulley definitely shouldn't 'wobble'...
Is your S/C a V1 or V2?
Is the idler pulley the 'stock' Stillen one? or aftermarket?
ASP idler pulley for the V2 DOESN'T include the bushing...
Old Jan 12, 2003 | 04:02 PM
BlackCat's Avatar
RIP '98 Maxima SE
Hi all:
You're saying that it fell into the gap between the pulley and the SC plate?
Sounds like the pulley is sticking a way bit out than it should because of the washers. I have my washer (1) on the bolt side, not against the mounting plate. (Mine's a V2 btw)
please help.
thx
The pulley shouldn't wobble at all.
Old Jan 13, 2003 | 07:51 AM
I have v2 with Dan's aluminum pulley. When I first start up the car, the belt running left and right on the idler pulley and then finally moved a rib on the alternator pulley and went into the gap between the plate and the pulley. When I tightend it down a bit more, the belt stayed, but it is running really close to the plate. like 5mm.
now it is running like this and about 2mm of the belt is NOT running on the idler pulley.
yup~
You are close to the right answer even without looking at it! I will post the cause of pulley not aligned in another thread.
hmmmm....when it is fully tightened, I can tilt the pulley a little. Seems the bearing may be a bit loose but I doubt it is the cause of the problem.
Old Jan 13, 2003 | 08:54 AM
BlackCat's Avatar
RIP '98 Maxima SE
Re: Re: Re: HELP~ the blet is running off the idler pulley~ HELP
[B]
yup~
[B]
I've got DanNY's pullies as well and neither of them wobbled.
If you have 2mm of the belt running off of the idler pulley then how's the belt on the tensioner pulley? Is it rubbing against one wall of the pulley?
If it is rubbing then you'll definitely need some washers to move the blower slightly away from the mounting plate. My belt is running right in center of both pullies.
Old Jan 13, 2003 | 09:56 PM
Re: Re: Re: Re: HELP~ the blet is running off the idler pulley~ HELP
The tensioner pulley is ok. The direction shifts at the SC pulley. seems the main pulley is the only cause of the problem, because Kevin didnt have any alignment issue with the 2.87
thx for the advice
Old Jan 14, 2003 | 08:11 AM
BlackCat's Avatar
RIP '98 Maxima SE
Re: Re: Re: Re: Re: HELP~ the blet is running off the idler pulley~ HELP
thx for the advice
Hmmm the main pulley? Never thought that that thing would wobble. I guess the locking pin isn't tight enough for that to happen.
Old Jan 14, 2003 | 09:30 AM
Re: Re: Re: Re: Re: Re: HELP~ the blet is running off the idler pulley~ HELP
sorry...I meant the main pulley is off by 2mm. The only pulley that wobbles is the idler.
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
ballerchris510
Sep 10, 2015 09:35 PM
