Engine life with turbocharging?
I was wondering, how long roughly do you think a VQ would last running 8psi boost?
My friend said 1 year, i was like no way it could only last that long. I would like to turbocharge my maxima but want it as a daily driver. Do any of you guys have any info on engine life?
Re: Engine life with turbocharging?
Re: Re: Engine life with turbocharging?
Originally posted by PCGuRu2K
VQ is one of the strongest engines around.. It'll last a good while. I mean if your not boosting constantly on a daily basis your motor should hold for a while. Longer then a yr for sure.
Re: Re: Re: Engine life with turbocharging?
Originally posted by Stephen Max
It's a good engine, but doesn't compare to the Supra engine, which can handle upwards of 900 hp on stock internals.
But its much better than my lawnmower?
Engine life is directly porportional to how you take care of it and how you drive it. Especially so w/ engines that are boosted(when not originally so)
So you can't say an engine will last xxxx miles with xx boost. Not really a valid question.
Let's say you have 2 maximas that can run w/ 20psi boost.
1 guy boosts it to 20psi at every light and never changes the oil.
2nd guy only boosts it to 20psi once every 2 days, changes his oil and watches his plugs etc.....
Which do you think is gonna live longer?
good example. (boost for dummies)
Re: Re: Re: Re: Engine life with turbocharging?
Okay, I wasn't trying to be a jerk or anything. I'm just amazed at how much power Supras can put out.
Speaking of lawnmowers, mine is a Honda. When is Nissan going to produce a VQ0.1 so I can maintain brand loyalty?
Mar 12, 2020 12:06 AM
