How many dyno runs does it take
Originally posted by Y2KevSE
The subject reminded me of the Tootsie Roll pop commercial.
1-2 hours. It all depends on how much you want to beat on the car to extract the most power.
Originally posted by Stephen Max
Hmmm. Okay, maybe I should rephrase. Will four runs be enough to tune the S-AFC so that it is within, say, 10% of optimal? I'm not sure if that makes any sense since this is completely new territory for me, but I gather that you start with a run, check power and AFR, tune the S-AFC in the rpm ranges where it doesn't look optimal, do another run, compare results, do some more tuning, etc. Is this basically how it's done?
Originally posted by PCGuRu2K
I believe I had to do like about 6+ dyno runs to get the line in my dyno as straight as possible...
thats over an hour in your in Lousiana your good you have 3 hours for $150, also if the guy knows how to work the SAFC very well should not take long tooo long like the guy did to my SAFC yesterday. My Dyno day will be thursday.
I had the same thought.. where is that wise old owl?
I've been trying to get in touch with a few places to get my car dyno tuned. I want to take it where MardiGrasMax recently took his here in MD. Someone told me he spent 2 hours tuning, maybe because he has more mods to configure, I don't know. Hopefully I get the same S-AFC tuner and hopefully he knows how to work the S-AFC2.
-Ben
-Ben
Originally posted by IgNiTe
the shop i took my car too charged $100 per hour. took about 7 runs to get it right
Originally posted by JAY25
took me about 7-9 runs, if you have your stuff ready to go is just all about how good the tech is with the adjusting the SAFC.
-Ben
Originally posted by BenBlanco218
Everything is ready to go, just have to get my baseline to figure out which rpm points to set and and adjust. I have a session tomorrow for an hour or more. I'm still learning the math, but I'm planning on adjusting the S-AFC2 myself and if he's available, he says he can probably help me with the adjustments. Hopefully I don't need more than 1 hour, I don't want to pay another $85 for the 2nd hour and come to find out thta I only needed like another 10 minutes.
-Ben
-Ben
thats fcked up if he charges you for a couple of more mins this dude we went about 1hr 30mins and only charged me for one hour. Hes a very cool guy like that. In any case the SAFC is not hard to tune, you should dyno first and then set the RPM points. It is set up to 8000RPMs he removed those and added the other useful RPMS if you know what I am talking about since our fuel cut off is @6600 somewhere around there.
http://forums.maxima.org/showthread....hreadid=196158
-Ben
IT took me like 20 runs to get my car tuned with a S-AFC. We did it in 1 hour! Yeah , the car was really HOT. Make sure u take an ice pack with u to put it on your charge pipe. It helps a lot with the cooling of your compresed air.
~AC
~AC
~AC
~AC
MAX POWER/TORQUE
MAX POWER/AIR/FUEL
-Ben
JoshG
51
09-21-2015 10:41 PM
RWCreative
09-21-2015 11:01 AM
ballerchris510
09-10-2015 09:35 PM
