Should I change FMU Disc from 8:1 to 6:1 I'm Running Rich??
Old Mar 21, 2003 | 08:24 AM
PCGuRu2K's Avatar
I checked with Stillen and the part that comes on v2 2000+ are indeed the 8:1 disc. And I'm running pretty rich at this point even with the AFC tuned at 23+%. Fuel Pressue was at 34psi. Now it's idling at 40psi. And gas miles have sucked lately. I get like 250 sometimes on a full tank. I used to get 300+ easily. So I guess I should look at getting the 6:1 disc so I can lean it out a bit and then retuning my AFC?
Old Mar 21, 2003 | 08:30 AM
Craig Mack's Avatar
All YOUR grammer belong to me
I'm running the 6:1 disc on my V1 w/a 3.33" pulley and 1 step colder plugs. I STILL get horrible milage. My fp idle is 38-41psi. I guess the colder plugs and stock fpr is killing me. The V2 makes a little more boost per psi then the V1 depending on the pulley, so if your running a 3.33" I'm not sure what you should do. If your running the stock pulley, then by all means switch. I hit something like 65psi at WOT with my setup which is good.
Old Mar 21, 2003 | 09:02 AM
PCGuRu2K's Avatar
I'm running on the 3.33" pulley
Old Mar 21, 2003 | 09:03 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Do you have an a/f curve?
Old Mar 21, 2003 | 09:06 AM
[maxi-overdose]'s Avatar
get an adjustalbe FMU
vortech : $280
cartech : $240?
here is my dyno, FYI
http://forums.maxima.org/showthread.php?threadid=197893
another 5th gen max has similar setup with AFC and his A/F ratio was exactly the same as mine before Kevin tuned the AFC. Kevin brought it back to a nice flat 12.5:1.
Old Mar 21, 2003 | 09:20 AM
PCGuRu2K's Avatar
If I remember right my af was like 12.5:1+ when I dyno'd. And tuning the afc it came down to something like 11:5 or so.. They guy at the shop said I was still running way rich..
Old Mar 21, 2003 | 09:37 AM
Y2KevSE's Avatar
12.5 is fine. Why did they continue changing the a/f?
If they went 11.5, it's actually running richer now. 11.5 is not as way rich as you think. It may even give you more hp than 12.5.
Old Mar 21, 2003 | 10:04 AM
Craig Mack's Avatar
I forgot to mention i'm running the Walbro HFP. Your not running the stock pump are you PCGURU?
Old Mar 21, 2003 | 12:34 PM
PCGuRu2K's Avatar
Yeap.. I'm still running the stock pump...
Old Mar 21, 2003 | 12:39 PM
Craig Mack's Avatar
Hmmmm.....you'd think you'd be running leaner if anything. Wtf?
Old Mar 21, 2003 | 12:49 PM
Y2KevSE's Avatar
He won't run lean since the stock pump + aux. pump can support the 2.87" pulley and still run rich (see [maxi-overdose]'s dyno).
The Frye
Sep 2, 2021 11:03 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
A32goldylocks
Sep 2, 2015 06:39 AM
