Post part numbers to the supercharger want to post a sticky etc..
I will start a facts supercharger thread on post it on top as a sticky if you have a part number or have a new blower and the packing slips have part numbers post them on here, after I get all the part numbers on this post I will start a new one and delete this one and just post one long sticky. I will post as much information as possible.
Thank you everyone
Thank you everyone
Originally posted by delio
Jay the packing slips do not have part numbers... It's part of Stillen's evilness... I on the other hand have master parts lists... hahaha
Originally posted by JAY25
I know you have your inventory at the house etc..but just wanted to get part numbers for these folks to use as a reference if they break some stuff or missing a part.
Originally posted by ejj
I think this is a really good idea.
Bill of Materials
Packing Check-off Sheet
Stillen Super Charger 95-99 Nissan Maxima
P/N 407000
oAssembly person _________________________
oDate: _____/_____/_____
oSales Order # ____________________________
oSupercharger serial number:________________
o Instruction sheet with pictures and schematics
o STILLEN SUPERCHARGED Plaque 100505 Assembled
by__________________ Date ___________
Materials supplied:
(1) Air Filter Assembly Assembled
(1) Silicone Hose, Blue - Æ3 ½” air filter to
supercharger 407000-11
(1) Steel Insert-air filter to supercharger 407000-02
(2) Hose clamp, #56 407000-14
(1) Blow-off hose nipple 407000-61
(1) Air filter with holes drilled 407000-10
(1)Vortech Supercharger assembly. Assembled
(1) Supercharger 407000-01
(1) Supercharger adapter plate assembly 407000-07
(1) M12x50mm Flat head bolt 407000-74
(1) Idler pulley 407000-26 (2) M12x70mm Flat head
bolt 407000-36
(1) Supercharger drive belt 407000-29 (4) 3/8-16 x
4 ½ Flat head bolt 407000-37
(1) ½-20 x 1 ½ Hex head bolt 407000-72 (1) M12
Flat washer 407000-73
(1) Fitting, -4AN Male – 1/8NPT male 407000-56 (1)
3/8-24x1 Flat head bolt 407000-76
(1) Intake tube w/blow off mount, Æ2 ½” with STILLEN
decal 407000-03 Assembled by__________________ Date
___________
(1) Modified thermostat housing assembly. Assembled
(1) Modified thermostat housing 407000-05
(1) Thermostat housing gasket 407000-63
(1) Crankcase breather hose assembly Assembled
(1) 36” Æ5/8” ID Crank case breather hose 407000-15
(1) 90° Æ5/8” OD Plastic vent line adapter 407000-66
(1) 45° Æ5/8” OD Plastic vent to air filter 407000-65
(1) 2” Æ5/8” ID Crankcase breather hose NEED P/N
(1)Oil feed line, -4 S.S braided line 407000-25
Assembled by__________________ Date ___________
(4) Adel clamps, Æ5/16”, w/Æ1/4” bolt hole 407000-51
(1) Oil Tee adapter assembly 407000-56,57,58
(2) M6x1.0x30MM HHCS 407000-46
(2) Aluminum spacers, ƽ” OD x Æ ¼” ID x ½” Long
407000-17
(1) Blow off hose to air filter Assembled
(1) Æ1” ID x 20” Long 407000-62
(1) Fuel pump assembly Assembled
(1) FMU (Fuel Management Unit) – Comes from Vortec
assembled
(1) Bracket, Auxiliary fuel pump 407000-09
(2) Rubber Insulators – Fuel pump bracket 407000-67
(2) Adel clamps fuel pump holder 407000-87
(2) ¼-20 Male stud/Female rubber isolator 407000-27
(2) ¼-20x1/2 Flathead cap screw 407000-85
(2) ¼ Flat washer 402991
(2) ¼-20 Nylon locking nut 407000-40
(8) Mini Hose clamps 407000-75
(4) 5/16” F/I fuel line 24” long each 407000-64
(2) Isolator to assembly bracket 407000-68
(1) FMU Bracket 407000-47
(1) –8 female AN to –4 Male AN, fitting 407000-59
(1) Electrical nuts to fuel pump (packaged from
Vortec)
(2) M6x1.0 HHCS w/washers
1) Auxiliary Fuel Pump electrical assembly
(1) Fuel pump relay electrical assembly (Bosch relay
from Vortec, Stillen Assembly Dept. to wire)
(1) Fuel pump pressure switch 407000-49
(1) Blue 3M splice NEED P/N
(1) Hobb/boost switch bracket 407000-55
(2) 48” Blue silicone hose each 407000-16
(1) Power Steering oil cooler-Stillen (1999 models)
See P/N 407100
(3) Adel clamps SG-6 (1999 models) Part of BOM of
P/N 407100
(3) M6 x 1.0 x 10mm Flange bolt (1999 models) Part of
BOM of P/N 407100
(1) M6x1.0 Nylon locking nut (1999 models) Part of
BOM of P/N 407100
(1) Back strap 18” long (1999 models) Part of BOM of
P/N 407100
(1) Coolant bottle relocation bracket 407000-50
(1) 48” 5/16” hose, radiator overflow to coolant
bottle 405030-9
(2) Spring clamps, overflow radiator hose 407000-70
(1) Fuse box mounting brackets (teardrop) 407000-31
(1) Fuse box relocation mounting bracket 407000-30
(2) Flat head 10-32 x 5/8 451070-4
(2) 10-32 Nyloc nuts 407000-42
(2) 90° 3” OD tube w/Air temp sensor hole & crankcase
vent Assembled by__________________ Date
___________
(push in type and bolt in type air sensor) w/nipple
(407000-20)
(1) Modified oil drain back plate 407000-06
(1) Blower oil drain back hose-preformed 407000-32
(2) Hose clamps, # 10 407000-23
Hardware – Intake tubes Assembled
(1) Silicone hose, Black - 90°, supercharger to cross
over tube 407000-13
(1) Silicone Hose, Blue - MAS to 90° Ø 3.00 tube
407000-12
(1) Silicone hose, Blue - 90°tube to Throttle body
407000-12
(4) Hose clamp #48 Hard pipe/Mas/Throttle body
407000-19
(1) Blow Off Valve Assembly with adapter 407000-24,
-8
(4) Cable Ties, 11” Black 405030-6
(2) Aluminum spacers – Stand off to valve cover
407000-17
(1) M8x1.25x40mm Flange Head CS 407000-69
(1) M8x1.25 Prevailing Lock Nut 407000-86
(8) M6x1.0x55mm Hex bolt 407000-45
(8) M6 lock washer 318109
(2) M10x1.5x60mm Hex bolt 407000-33
(2) M10 flat washer 407000-34
(6) M6x1.0 Nyloc nuts 402993
(12) M6 Flat washers 318110
(6) M6x1.0x25mm Hex bolt 402990
(2) M6x1.0x40mm Hex bolt
(2) Hose Clamp #40 – Supercharger to 90°hose
407000-18
Vacuum line assembly Assembled
(3) Vacuum Tees, 3/16” 407000-28
(5) Cable Ties, 6” black 505053
(5) Vacuum lines, 3/16” ID 503215-6
(1) Air-bypass adapter 407000-78
(1)Cam sensor retainer 407000-84 Assembled
(1) C.A.R.B. Decal EO#D436-6
(1) 92 Octane Label WARNING
(1) Stillen SuperCharged Decal STISUPERdd
Originally posted by Stephen Max
I've got this:
Bill of Materials
P/N 407000
Materials supplied:
bolt 407000-36
___________
407000-17
assembled
Vortec)
See P/N 407100
P/N 407100
BOM of P/N 407100
BOM of P/N 407100
P/N 407100
bottle 405030-9
___________
(407000-20)
over tube 407000-13
407000-12
407000-12
407000-19
-8
407000-17
407000-18
I've got this:
Bill of Materials
P/N 407000
Materials supplied:
bolt 407000-36
___________
407000-17
assembled
Vortec)
See P/N 407100
P/N 407100
BOM of P/N 407100
BOM of P/N 407100
P/N 407100
bottle 405030-9
___________
(407000-20)
over tube 407000-13
407000-12
407000-12
407000-19
-8
407000-17
407000-18
I have something cleaner than that at home, for both the V1 kits and the V2 kits.
I'll see what I can dig up.
mrc00l88
Jan 25, 2024 01:14 PM
ah2002
Mar 9, 2016 01:42 PM
BassAddictJ
Aug 4, 2015 11:38 AM
