LONG trips w/ boost, safe or not???
Old Apr 9, 2003 | 10:51 AM
20thdriven's Avatar
Kind of a newbie type of question but I'm pretty hesitant to take my max on long trips with the SC. I've gone ~5 hours on the highway w/ no problems. An oil cooler is probably imperative. I'm assuming long trips shouldn't be an issue especially if you're good at a belt change. Anyone go cross country???
Old Apr 9, 2003 | 10:56 AM
BigDogJonx's Avatar
Re: LONG trips w/ boost, safe or not???
Ive driven the turbo to 1000mile trips with no issues.
Dixit
Old Apr 9, 2003 | 11:13 AM
PCGuRu2K's Avatar
Re: Re: LONG trips w/ boost, safe or not???
Dixit
Yeah but with turbo's if your blower goes at least you can still drive. Once our belt shreds we're dead .
Old Apr 9, 2003 | 11:25 AM
max'n out's Avatar
IT will be fine, Ive taken many long trips, just watch heat like normal.
Old Apr 9, 2003 | 11:29 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
When we travel to SoCal, I always bring all the tools needed to do a belt change just in case (bring an extra belt too).
Old Apr 9, 2003 | 11:39 AM
hlh0501's Avatar
I took a 2100 mile trip recently in two days, no problems and got incredibly good mileage. 29.5mpg avg even on one tank
Old Apr 9, 2003 | 11:43 AM
max'n out's Avatar
GO read my afc post and help a brova out
Old Apr 9, 2003 | 11:47 AM
Y2KevSE's Avatar
Originally posted by max'n out
GO read my afc post and help a brova out :-) ;-):-p
OK, but say "uncle" first.
Old Apr 9, 2003 | 11:49 AM
max'n out's Avatar
Never!!!!
Uncle
Old Apr 9, 2003 | 11:54 AM
Y2KevSE's Avatar
Never!!!!
Uncle
I was only kidding, Jayson.
Answered.
Old Apr 9, 2003 | 11:56 AM
max'n out's Avatar
Answered.
I know
Old Apr 9, 2003 | 02:49 PM
[maxi-overdose]'s Avatar
to make it easier....bring a shorter belt instead. if your SC belt shredded, put on the shorter belt on the crank, AC, alternator and tensioner. At least you dont have to run on battery.
that's what I would do, because I know I can't take out the SC in 40 minutes.
Old Apr 10, 2003 | 09:37 PM
JAY25's Avatar
I just took a trip to New Orleans, had a good time etc..no problems, except that I was due for an oil change while I was out there. Everything seem to be just fine
Old Apr 11, 2003 | 12:05 AM
BippuBenji's Avatar
That's exactly how I feel, I can't see myself trying to remove the blower on the side of a road. So I assume I can just put on the stock size belt and bypass the blower pulley? Is there anything else I need to know about for any of the other SC parts, like do I have to worry about oil circulating through the blower when its not even put to use (bypassed), can I leave the BOV the way it is? I assume the FMU is fine because it won't turn on without boost. I already know that I have to reset my s-afc to 0 settings. Since I'll be taking the Max on a 4-hour road trip next week, what else should I know about?
-Ben
Old Apr 11, 2003 | 10:06 AM
20thdriven's Avatar
Re: Re: Re: LONG trips w/ boost, safe or not???
-Ben
someone please reply to this b/c less than a handful of members can change SC belts on the road. Took me 5 hours in a garage. Will using the stock belt work and will oil still circulate through the SC? This could be VERY helpful information.
Old Apr 11, 2003 | 10:13 AM
ejj's Avatar
ejj
Re: Re: Re: Re: LONG trips w/ boost, safe or not???
If your belt shreads, you don't have to remove the blower. Just install a new belt (stock one) without looping it around the blower. It would only take as long as changing the AC/Alternator belt does on a car without the supercharger.
Old Apr 11, 2003 | 11:01 AM
someone need to answer this one for me: will the hot oil damage the blower if the blower is not spinning? How does the oil flow in the blower? gravitaional? or driven by force?
you dont need to worry about your BOV. if there is not enough pressure, it is not going to open. correct on FMU.
if you decided to go with a shorter belt as back up, you might need following tools.
screw drivers
10mm scoket
14mm scoket
12inche extension
wrenches
anything else?
-Ben
Old Apr 11, 2003 | 11:26 AM
Y2KevSE's Avatar
No...
Pressure, just like how it goes to the blower now.
Drain is gravitational.
To blower is by force.
Old Apr 13, 2003 | 09:53 PM
Re: Re: Re: Re: Re: LONG trips w/ boost, safe or not???
No...
thank you, boss
jmlee44
Oct 2, 2022 02:13 PM
BobTX10
Oct 7, 2015 08:43 AM
sliptap
Sep 30, 2015 05:57 AM
Andy29
Sep 29, 2015 05:32 AM
