Raced my friends n/a '99 Max 5spd, VERY unhappy with the results
Old May 21, 2003 | 12:02 PM
  #81
Stephen Max's Avatar
Originally posted by Craig Mack
Dave, my rims weigh 24lbs. a peice, which isn't bad for an 18x8.5 rim for the price it was. So, with those and my 245/40/18 Nitto 555's, my setup shouldn't be any heavier if even as heavy as his. What mods does he have BTW? Wouldn't you agree that my rims would have a much more significant effect on a n/a maxima then the same max @10psi? Even though it's linear boost it should still negate the effects of a heavy rim...
If I were to go back to stock 15" sawblades the results would be bad. I already can spin the tires in first from a roll, and usually spin into second. With the stockers I can only imagine my traction problems. Besides, I am not ALL go, I love the way the rims make my car look and the compliments they bring...
Even though the rim and tire may way the same as 15" sawblades, the radius of gyration is significantly higher, since the 18" rims concentrate the wheel weight at the rim. So you've got a lot more wheel inertia to overcome just due to geometry. In addition, you need more torque to accelerate a car with large wheels, since the opposing force at the tire contact patch is at a larger radius.
On the other hand, as you rightly state, first gear with sawblades is virtually useless.
Old May 21, 2003 | 12:14 PM
  #82
Jeff92se's Avatar
I'm needing a caw
Craigo. No dyno, no comment. Nuff said.
Old May 21, 2003 | 12:18 PM
  #83
Craig Mack's Avatar
All YOUR grammer belong to me
Steve,
I realize that the larger a rim is, the more power it's going to take to rotate it. That's nothing new. If anything, I feel that the wide/slightly heavy 18's help keep me planted to the ground. I can't imagine the kind of torque steer I would get with the tiny 15's, I would probubly swerve off the road. (somehow I think Dave B. is going to say the exact opposite of this)
Old May 21, 2003 | 12:21 PM
  #84
Craig Mack's Avatar
Jeffco, notice how I didn't say "well since my car has 350hp and 313TQ I should be..blah blah blah..." I want to dyno very soon!! I'm very anxious to see what kind of power my car is making and see if there are any places I can improve on..
JeffreyN/A-VE has Craigy10psi-VQ envy
Old May 21, 2003 | 12:26 PM
  #85
Jeff92se's Avatar
I'm needing a caw
Well Craigmont soda, if you dyno'd within' the last year, 99.99% of your oddball questions would have been automatically answered right?
I only envy your parent's $ Craigmont soda
Old May 21, 2003 | 12:44 PM
  #86
Steve,
Cool. Then you understand what we're saying that even though your wheels may not weigh more than say, sawblades, your acceleration is going to suffer due to the increased size.
I like my sawblades for that very reason, but I gotta admit Maximas look so much better with the right aftermarket rims.
Old May 21, 2003 | 12:53 PM
  #87
Y2KevSE's Avatar
Rice Boy in Denial =)
Ask your parents to buy you a turbo.
Old May 21, 2003 | 01:00 PM
  #88
Jer's Avatar
Jer
Old May 21, 2003 | 01:40 PM
  #89
Craig Mack's Avatar
Nah, I think i'll ask em for a 2002 SS 6spd, and keep the Max as a beater. Go straight for the brute power, whaddaya think?
www.JeFFrEy92sElIkEsMeN.com
Old May 21, 2003 | 01:47 PM
  #90
Jeff92se's Avatar
I'm needing a caw
Craigylikescats
Old May 21, 2003 | 01:48 PM
  #91
Craig Mack's Avatar
Craigylikescats
Cats huh? Interesting...
Old May 21, 2003 | 05:31 PM
  #92
99Maxima5sp's Avatar
so whens she getting dynoed craig?!
Eric
Old May 21, 2003 | 08:13 PM
  #93
Dave B's Avatar
Not DAVEB the parts guy
Traction is HEAVILY dependent on the type of tire you're running. Run crap tires on the 15" rims and you'll spin forever. Put sticky tires on there and traction is fine. I recently replaced the OEM RSAs on my sawblades and traction is immensely better. I'm running Sumitomo HTR 200s (V-rated summer). Wide low profile tires are good for turns, not necessarily straights. I hook up better with my 15s than I do with my sticky W-rated 17s. Ever since purchasing sticky tires, I don't have problems with excessive spin in 1st like I use to. I've got considerably more power than I did a year ago and I can mash the gas in 1st from a roll (going straight) with no worries of the tires spinning. I barely chirp 2nd either.
I guess I'm not saying to dump the 18" rims for the street, but be aware that you are definately slower with the 18s. The heavier weight and huge enertia required to spin big 18s is substainial and seeing that the Vortech doesn't make huge torque, the rims suck out power. When you go to the track, run your 15s. Even with bald RSAs I was able to grab a bunch of 2.2 60 foots. The trick is not to get greedy with the throttle. Wind up to 3000rpms and slowly slip (don't burn it) the clutch to get the car rolling and when it hooks up, progressively add gas and release the clutch. NEVER dump the clutch nor release it terribly fast. Let the SC do the work for you. If you pull off a 2.3 60' you'll be doing pretty for racing with a SC.
Dave
Old May 21, 2003 | 09:17 PM
  #94
Craig Mack's Avatar
Dave
I hate (well i do now) quoting how much power my car has without actually dyno'ing, but based on similer setups I should be putting out over 300ft/lbs of torque to the crank. I guess it's just the way that torque is delivered (linear) that is the main deficit.
Do you honestly think that I would fair better with 15x6.5" rims with stock sh!tty tires vs. 18x8.5" rims with W-rated Nitto's? My car handles significantly better with this setup versus my only 17x8's with the H-rated Kumho's, and I can get up and going from a stop pretty good if I try hard. I'm sure with my nerves and lead foot at the track, even if I push the peddle down a HAIR too much with the stockers i'll just blow through first. The first time I tryed launching with my current setup, I accidently redlined it by touching the throttle just a bit too much.
I can't wait to hit the track though. June 5th marks the beginning of a new era for me. I'll be at orlando speedway like everyweek.
Erica: I need to call a place. Turbo Tom said theres a place on Colonial (orlando) that's very reputable. I'll have to call when I have some free time.
Old May 21, 2003 | 09:40 PM
  #95
craigy: do you really think you will be at the track every saturday/sunday?! If so, be prepared to take it to the shop on monday...that biatch wont last....
Eric
Old May 21, 2003 | 09:49 PM
  #96
Craig Mack's Avatar
Eric
Old May 21, 2003 | 10:02 PM
  #97
Eric
Old May 22, 2003 | 05:24 AM
  #98
mzmtg's Avatar
Minister of Silly Walks
What do you tell people?
When someone says, "Holy crap, a supercharged Maxima! How much power does that thing make?" The correct answer for you is, "I don't know, I haven't dyno'd it yet."
Old May 27, 2003 | 04:07 PM
  #99
Craig Mack's Avatar
Yes sir.
JoshG
Sep 16, 2015 08:56 PM
220k+ A32
Sep 11, 2015 02:18 AM
16_SR
Sep 9, 2015 07:14 PM
MaxLife17
Sep 8, 2015 02:36 PM
jwright36
Sep 8, 2015 11:45 AM
