To those with turbo's what rpm do you see the boost start??
Old Jun 13, 2003 | 01:43 PM
Bags's Avatar
VG Ridah's Biatch Hoe
On my t3/t4 it starts at 2400 rpm... I have 1 psi then and I am at full tilt by 3500 rpm
I am just curious what others are seeing
thank you
Old Jun 14, 2003 | 03:15 PM
RS Motorsports's Avatar
Re: To those with turbo's what rpm do you see the boost start??
thank you
on my t4/to4e i start to see boost at about 3300 rpm and full boost at around 4000 rpm.
Ryan
Old Jun 14, 2003 | 03:30 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
damn that's a long time to spool, then again u guys are both auto..
Old Jun 14, 2003 | 04:07 PM
Ramius83
Kev I know is seeing full boost by 3400 on his T4 Ball Bearing....
Old Jun 14, 2003 | 09:55 PM
MaxSpeedSE's Avatar
thank you
Redline
Old Jun 14, 2003 | 10:51 PM
Shadow's Avatar
Still a heck of a lot better than the SC. I hated watching my boost gauge hit full boost at redline, and then immediately drop at the shift.
Can't wait until I can peg it at 3 or 4K and just watch it stay there.
Old Jun 15, 2003 | 12:57 AM
joaquink's Avatar
¿Hablas Español?
I think I have full boost around 3.5K for most driving situations (when the car is working). I run a t3/t04e.
Old Jun 15, 2003 | 06:08 AM
Bags's Avatar
uhh.. compared to what?
The best I have seen was spooling at 1800 rpm and max at 2400 rpm, but that was a small turbo .. don't even know the size
Old Jun 15, 2003 | 06:58 AM
turbomax97's Avatar
umm all the turbo'd guys around here spool and are at full boost from ~ 2200-3k rpm.... Some are running T25's, but most are at T3/T04's
Old Jun 15, 2003 | 09:01 AM
Ramius83
Bags, I think there may be something up with your setup. You should definitely be seeing full boost by 3000, especially with the T3/T4. Do you have the specifics of your turbo, ie the specific trim sizes and such. Also, what are Dixits numbers here? And what trim sizes does he have? He is the one we really need to add to this because we can compare almost two identical kits, just on two different cars. You can't really ask this for the people that have Nigel's kit or custom because most of them are running T4s.
Old Jun 15, 2003 | 09:22 AM
Bags's Avatar
I think part of it is the turbo leaking oil still and the reverse y-ipe.
The way the front pipe comes down and into th other pipe is NOT effiecnt
if I can get some time grand will make me another pipe.. just hard to loose the car for 2-3 days
Old Jun 15, 2003 | 01:21 PM
Ramius83
Yeah, I hear you. That is true about the reverse y-pipe. With that front pipe going straight down, you are loosing a TON of efficiency there. That whole pipe needs to have a "2-1 collector" there. If you need any help with it, just let me know....
Old Jun 15, 2003 | 07:11 PM
Deac's Avatar
thank you
With my t4/60-1, I start to get boost at between 3500 & 4k I'd say, Have'nt paid too much attention to it becuase I still have not had a chance to tune my car properly yet.
Deac
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
bryants95max
Oct 2, 2015 12:52 PM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
