OK - I need ideas
OK - I need ideas
I've spent a year trying to figure htis out.
I'm not going to say what I've tried - I'm just going to tell you all the symptoms and let you guys throw ideas out there.
V1 SC - 3.12" Pulley
Vacuum is at 15Hg
Boost in all gears:
1st Gear - 8-9PSI
2nd Gear - 6-7PSI
3rd Gear - 5-6PSI
It seems the longer I am in boost, the less boost I get.
Vacuum is at 15Hg
Boost in all gears:
1st Gear - 8-9PSI
2nd Gear - 6-7PSI
3rd Gear - 5-6PSI
BOV needs a tighter spring or to be cranked down. I had the same problem but could not get more than 6 psi at WOT (with a V2 & 3.125 pulley). I changed out the spring to a stiffer one and tightened the set screw a little and WAAA LAAA I had 12.5 psi.
Yeah - I knew that would be said first.
I've installed 2 BOV's, the latest being a HKS SSQ that is supposedly impossible to boost leak because it mechanically can't activate at all unless there is vacuum.
OK - I may as well list what I have done.
2 different BOV's
Checked SC Piping/clamps constantly - no holes or leaks - RTV'ed Ambient Sensor into place
Removed and re-installed MEVI with new gaskets - used RTV on top of that.
Used a stethascope on every vacuum hose I could find using the FSM - no cracks or holes found.
Compression checked - 210/cylinder
Replaced PCV Valve
Replaced all plugs - regapped.
Tried 2 different belts - tried tightening it, loosening it, then tighteneing it again to 70 degrees deflection.
3 different boost gauges.....installed on several spots off the manifold.
Replaced EGR, TB, and Manifold Gaskets.
I generally post this question every 3 months, hoping someone knows something I haven't checked yet.
2 different BOV's
Replaced PCV Valve
I just won this on EBay - hopefully it helps.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
IanS
IanS
Did another compression check (just to be sure) again today - 173-176 in all cylinders - (all but 2 were at 175).
Pretty consistant and well within spec.
Waitingo n the vacuum leak detector to show and see if that helps.
Gone through 2 belts now - doing about 60-70 percent deflection just like you once suggested, Mardi.
According to my Dynos from last week, there is no evidence of any slippage.
IanS
IanS
tarun900
19
Dec 20, 2021 06:57 PM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
