Supercharger Pully Bolt part number
Old Jul 16, 2003 | 06:16 AM
ejj's Avatar
ejj
Stripped the head of the bolt. I'd really like to change the pully when everything is out of the car, but I'll need a new bolt to put in there.
Anyone know that part number. I'm refering to the bolt that holds the pully to the SC.
407000-74?
Old Jul 16, 2003 | 07:21 AM
Stephen Max's Avatar
Re: Supercharger Pully Bolt part number
407000-74?
Eric, there's no need to order a bolt from Stillen. Once you get the old bolt out (I had to drill mine out) you can get the size and tpi from the remnants and get a new bolt from your local industrial nut and bolt supplier (not Home Depot). I suggest getting a grade 8 bolt. The bolt doesn't need to be that strong to hold the pulley on, but the additional strength will make it harder to strip the head next time.
Or you can order a bolt and washer directly from Vortech:
http://www.vortechsuperchargers.com/...ategory_Code=P
Old Jul 16, 2003 | 07:33 AM
ejj's Avatar
ejj
Re: Re: Supercharger Pully Bolt part number
Steve - Thanks for the info!
Is this the kind of bolt that nut & bolt suppliers will stock, or am I going to be stuck ordering one? I want to put the engine back in this weekend, and would prefer to do the pully swap on the SC as well. Do you recall the size information so I could call around before going on a wild goose chase?
I could overnight it from Vortech...but that's $30 for a stupid bolt...not worth it.
Thanks for the help!
Old Jul 16, 2003 | 07:47 AM
Re: Re: Re: Supercharger Pully Bolt part number
It's a standard size, so a supplier should have it. I ended up getting a regular hex head bolt (I wish I could remember the size and tpi), instead of a button head cap bolt that comes with the kit. Since the hex head sticks out a bit further than a button head I used a regular washer instead of the thick, chamfered washer that comes with the kit because of the tight clearance with the timing chain cover. I used Loctite to keep things in place.
Speaking of Loctite, the original bolt was held in place with lots of red Loctite, so I had to heat the pulley and blower shaft with a heat gun to soften the Loctite to the point it would let go of the bolt. This was after drilling the bolt and trying to use a bolt extractor on the remaining bolt threads. If you use heat from the start you will probably have an easier time than I did.
Old Jul 16, 2003 | 08:08 AM
[maxi-overdose]'s Avatar
I bought that bolt from local hardware store. it is a FHCS (flat head cap screw) and the size is....3/8-24 * 1 in. FHCS. It is highlighted in the SC partlist stickie.
Stillen part no. is 400700-76.
Instead of loctite....I use antiseize instead on all the FHCSes as Maridgrasmax recommended. no problem so far.
Old Jul 16, 2003 | 08:11 AM
ejj's Avatar
ejj
Awsome! Thanks for the info.
I used antiseize on all the bolts on the SC plate when I took them off the first time. They all came out like a charm...but I hadn't done anything with this one yet.
Thanks.
Old Jul 16, 2003 | 08:43 AM
Thanks.
no problem!
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
