Installed AEM FPR, and FP keeps dropping, along with a HORRIBLE ignition, help.
Old Aug 18, 2003 | 01:07 PM
Craig Mack's Avatar
All YOUR grammer belong to me
We installed the AEM FPR and set it at 34psi. Well, over the last couple days it has steadily dropped to ~29.4psi. At start-up, it's a little higher, but has been very slowly but steadily dropping.
Also, starting the car is HORRIBLE. It stutters several times and finally cranks over weakly, when before it was an instant clean start. Also, the last time I put the key in and turned the battary on. (turn on gauges) FP only went to ~11psi then dropped back down to 0. WTF?
I don't feel safe boosting when the car is acting up like it is. Thanks in advanced for the help.
Old Aug 19, 2003 | 10:53 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Sounds like a typical AEM product.
I'd try something else or run stock until you get that figured out.
Old Aug 19, 2003 | 10:56 AM
Stephen Max's Avatar
Yeah, sorry to say, Craig, those are my thoughts, too.
Old Aug 19, 2003 | 10:58 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
yup, the general consensus over on HT is AEM FPRs = crap too!!!
Old Aug 19, 2003 | 11:11 AM
IceY2K1's Avatar
You pu$$ies! I was waiting for someone else to SMACK him, but nobody replied.
So I finally reply and within 5mins. you guys jump in.
Old Aug 19, 2003 | 11:36 AM
DA-MAX's Avatar
Old Aug 19, 2003 | 01:10 PM
Craig Mack's Avatar
Thanks for the help guys.
It's not the FPR, or if it is, then it's one EXPENSIVE peice of ****. Sx7r and SeximaGTR are running it and have great things to say about it.
I guess I will have to readjust the FP back to 34psi. I heard sometimes new units take time to adjust into place, which makes sense.
Old Aug 19, 2003 | 05:28 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
the fpr is fine for me.... are you sure your locknut is tightened?
Old Aug 19, 2003 | 06:06 PM
Craig Mack's Avatar
Locknut is tight, all lines are secure, elbow is secure, ect. Yet I still got about 6-7 bad stutters before the car kicked over. The FP rose to 34psi, but it was because my car was cold and it had a high idle. My fuel pump is fine, becuase up until the time of the FPR install my car started flawlessly. But then again, my FP used to rise to normal when turning the key to battery-on, but now it goes up a little and dies back down to 0psi.
tsi6001
Oct 3, 2022 10:23 PM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
305head
Aug 26, 2015 09:03 PM
