mas before s/c?
Old Sep 17, 2003 | 09:45 PM
3000GT's Avatar
mas before s/c?
have any of the 4th gen guys put the mas on the intake side of the s/c? i know the newer kits for 2k have them before but i have tried this and am having some surging problems.
Old Sep 17, 2003 | 10:22 PM
Bags's Avatar
VG Ridah's Biatch Hoe
From what I have read for the past 2+ years there have been NO problems reported with the 4TH GEN sc kit and the MAF.
NOW the 5th gen is another story.
Old Sep 18, 2003 | 11:11 AM
Stephen Max's Avatar
I will be putting a Z32 maf on the intake side of SC in a month or so.
Are you recirculating the bov air?
Old Sep 19, 2003 | 09:44 PM
3000GT's Avatar
mas before s/c
heres the deal--i have a 97 se with a 2000 motor. the s/c is a s trim unit (much more boost)and running a apex front mount air/air intercooler. i moved the mas to the intake side and have been surging bad. if i move it back to the intake side, how much psi can the factory units take?(4th gen)also-should i install the air temp sens on the intake side of the s/c, before the i/c inlet. or after the i/c outlet?
Old Sep 19, 2003 | 09:46 PM
3000GT's Avatar
im not recir. the air. the surging is happening even with the bov disconnected.
Old Sep 19, 2003 | 09:49 PM
From what I've read here on the org, a 4th gen maf has yet to be blown from too much boost.
The air temp sensor is not used by the ecu for controlling afr. Put it wherever is most convenient.
Old Sep 22, 2003 | 05:37 AM
Sounds like you may be having a boost leak. Is the surging mostly at idle?
Old Sep 22, 2003 | 08:14 PM
3000GT's Avatar
surge
nope. the surge is all through the rpm band. i unplugged the mass air and the car ran good.(except for the code-it put the ecu in fail safe)
Pmp-n8a
Feb 10, 2001 01:54 PM
My 4DSC
Dec 26, 2000 07:33 PM
Gotrice4
Sep 21, 2000 08:34 PM
Mr. Rose
Sep 18, 2000 05:29 PM
Mr. Rose
Sep 8, 2000 05:07 PM
