Where can I find a 9/16"-18 thread plug?
Old Oct 27, 2003 | 07:10 AM
1MAX2NV's Avatar
I'm trying to install my AEM universal fuel pressure regulator and it has an extra inlet port I need to seal up. Where could I find this plug? Is it something I can pick up at Home Depot?
Old Oct 27, 2003 | 07:28 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
it should have come with the fpr.... in that little baggie of fittings
Old Oct 27, 2003 | 08:32 AM
1MAX2NV's Avatar
This is all I got from AEM.
http://www.sx7r.com/images/aemfpr.jpg
There wasn't a big plug for the inlet port. I don't think I even got a plug for the gauge port, but that's no big deal. 1/8 NPT is easy to find.
Old Oct 27, 2003 | 09:32 AM
turbomax97's Avatar
i'll look around, see if i have it sitting around, i didnt use mine since i plugged my fp guage sending unit there...i'll pm ya 2nite
Old Oct 27, 2003 | 11:09 AM
Requin6's Avatar
tony, summit has it. i just put the AEM FPR in and got all the neccesary fittings/couplers/plugs from summit.
here is the plug you will need. its just a -6AN plug. Part# : EAR-581406.
http://store.summitracing.com/partde...t=EAR%2D581406
they come in a pack of two, i only used one. i have the extra here if you wanted i could mail it to you. let me know.
the -6AN to 9/16"-18 fitting adapter is for where your hose ends go. do you need the plug or the adapter? the adapter looks like this...
http://store.summitracing.com/partde...t=EAR%2D985006
--Paul
Old Oct 27, 2003 | 12:25 PM
1MAX2NV's Avatar
Thanks for the info Paul. I got some questions for you. Did you change the orifice? Which fuel pump are you running? Which fuel rail off fitting are you using?
I ended up ordering Earl's swivel seal hose ends and auto-flex hose. I'm plan on using Econo hose clamps at the fuel rail off fitting barb and the OEM fuel return barb. Kinda ghetto using expensive Earl fittings at the FPR and using econo hose clamp for the barbs.
Old Oct 27, 2003 | 12:50 PM
Requin6's Avatar
actually i did change the orifice. i thought it was the fix to a problem i was experiencing. but it turned out to be something else and i left it in. so i have the middle sized orifice in there. it runs perfectly fine, i didnt run it with the smaller orifice so i am not sure of the difference. but the middle one runs perfect.
i am using the walbro GSS342HP fuel pump. and i am using the off fitting from sx7r's site. its like $25.
i havent gotten around to putting the SS line in, i am just using the regular rubber fuel hose for now. since the summit brand was the cheapest for the 90degree -6AN swivels i just picked those up. all in all it looks great and serves its function....
--Paul
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
doctorpullit
Sep 10, 2015 06:33 PM
mikebla
Sep 3, 2015 05:37 PM
sdotcarter
Sep 2, 2015 09:53 PM
