which clutch did you guys use?
for a SC or turbo maxima manual running 3.125 or 2.87 pulley which clutch did you pick and why?
i am doing reasearch right now i want to swap to 5 spd soon and would like some opinions.
are blowing trannies up a result of a clutch being to strong for the tranny or driver error?
thanks
frank
thanks
frank
Originally Posted by ejj
I'm using an ACT "street disc"...don't recall the part number, but its the one that just about everyone is using.
Driver error and abuse.
highly agreeACT street disc and Mod Pressure plate
I will be NA for about 9 more months but I am converting to 5 speed next week. I wanted to get the Stage 2 4-puck by ACT but do not want a very harsch engagement. Have an opinions on the Stage 2 or would I be ok with the Stage 1 kit once I go turbo??
-Tony
-Tony
i am a Direct Dealer of Daikin (O.E.M) Clutch Kit & Exedy Clutch Kits
EXEDY SPORTS & PERFORMANCE CLUTCH PRODUCTS
Hyper Single Clutch:
The Hyper Single Clutch is engineered to optimize performance for cars that are moderately modified, but do not require the clutch capacity of a multi-plate clutch. Similar to our multi-plate clutches, it has a forged aluminum cover that is anodized purple. The aluminum cover is stiffer than a stamped cover and therefore allows a higher lever ratio to maintain the pedal efforts at a reasonable level.
All Hyper Clutches come with a steel flywheel and a 6-puck cerametallic facing, spring center damper disc assembly. The disc is generally smaller and thinner than the OEM disc making for lower inertia and therefore quicker, easier shifting and less wear and tear on the transmission synchros. The higher clamp load and cerametallic friction facings give approximately twice the holding torque of the OEM clutch and generally higher than other single plate clutches.
As with all cerametallic clutches, the street driveability may be marginal due to chattering and harsh engagement characteristics.
An additional feature of the pressure plate is a series of turbine-like, air flow enhancing vanes that keep the clutch cooler under extreme operating conditions to improve wear life. For Purchase information Please Click Here: :: EXEDY SPORT & PERFORMANCE CLUTCH SPECIALIST'S ::
Multi Plate Clutch:
For high-powered applications, EXEDY offers twin and triple Multi-Plate Clutches. These are designed for hot street action as well as drag, road and rally racing.
The twin plate clutches are rated for above 500hp to 750hp. The triple plate clutches are rated for up to and over 1000hp (for drag race applications). Twins come as with both spring damper discs and solid discs. Triples are all solid discs.
All of our multi-plate clutches come with a lightweight, chrome moly steel flywheel and the famous purple anodized forged aluminum clutch cover. Depending on the application, we have both strap drive and lug drive models. All have T5001 cerametallic friction materials for extreme heat resistance.
Engine modifications e.g.. cam-timing-turbo modifications etc. cause engine pulsation and vibrations. These vibrations can cause clutch rattle when the clutch pedal is depressed by movement on the intermediate separator plate in some applications. These noises will in no way affect the performance of the Exedy Multi Plate Clutch. This rattle is well accepted in the performance industry where engine modifications have been carried out. For Purchase information Please Click Here: :: EXEDY SPORT & PERFORMANCE CLUTCH SPECIALIST'S ::
Multi Plates Twin Plates Honda Twin
Single Plate Organic:
EXEDY Racing clutches with organic friction materials use only premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines.
The driveability will be like a stock clutch. Pedal efforts will be higher because of the higher clamp loads. All of our clutch discs have high capacity spring center dampers to reduce the drive train shock and impact. For Purchase information Please Click Here: :: EXEDY SPORT & PERFORMANCE CLUTCH SPECIALIST'S ::
Single Plate Cerametallic:
EXEDY cerametallic clutches are designed to handle the abuse of high power modified engines. Our cerametallic friction material can handle much more slippage than stock type disc assemblies without slipping and fading.
All EXEDY cerametallic clutch discs have spring center dampers to reduce the impact and shock loads put into the drive train. This protects the transmission and the rest of the drive line system.
We offer two types of cerametallic discs -normal thickness and reduced thickness.
The reduced thickness (thin cerametallic) discs offer greatly reduced inertia to improve shift efforts, make for faster shifting, and improve synchro durability. These discs are approximately 1/2 the thickness of a stock disc.
The normal thickness (thick cerametallic) discs have better heat capacity and therefore better durability in demanding applications such as all wheel drive. Even with the normal thickness, our three puck cerametallic discs still typically have less inertia than a stock disc.
With any cerametallic clutch system, there will be some compromise of start up driveability as compared to a stock clutch (chatter on light throttle, low rpm start up). This characteristic is generally felt to be acceptable in modified performance cars. Drivers of cerametallic clutches on the street should be warned not to "ride the clutch" to try to reduce the chatter as this will http://www.mitsubishigraveyard.com/directgreatly increase the wear. For Purchase information Please Click Here:
Cerametallic Thick Cerametallic Thin
Racing Flywheels:
EXEDY Racing Flywheels are made from solid one-piece billet chrome moly steel or chrome moly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel which has the possibilities of separating from the flywheel. This could cause the flywheel to explode due to two different expansion coefficients (aluminum flywheel pressed on steel ring gear). EXEDY steel billet and forged steel flywheels have passed engineering tests to 15,000 rpm. They are guaranteed to be explosion proof at the said rpm. For Purchase information Please Click Here: :: http://www.mitsubishigraveyard.com/direct.html[/url]
Multi Plate Clutch:
Racing Flywheels:
Originally Posted by mtcookson
so you get a flywheel along with the clutch kit? how much is that kit?
If your going to get a flywheel, you might as well buy a Fidenza
Originally Posted by spanishrice
I would like to know how people are mistrating their tranny to blow up. What do they do?
dumping the clutch. They take their revs up high and dump the clutch. I ve also noticed that some people dont realize that they are damaging their tranny and damaging the clutch disk at the same time. I dont know why people blame it on the clutch. Think of a clutch like a hammer. Is a good tool if you used properly. It can be a destructive tool if used incorrectly. The clutch clamps hard. If you dont know what your are doing by missing a shift, going from 2nd gear to 1st gear or from fourth to 1st gear etc..at high rates of speed and grinding gears, letting the tranny hop the wheels and all that crap it will damage the internals and possibly the tranny case like I did.
Last night I raced a Z28, the first run I went from 2nd to third and could not get the car in gear. Kept the clutch pedal pressed and finally got in third. I lost the run, but my tranny has plenty of life to go many more rounds. Thats all that matters to me. For someone whos anxious and impatient would have just threw the car in 1st gear and bye bye tranny in a couple of weeks. Thats how simple it is to start the damaging process.
I've talked to ACT yesterday and was told that the four puck supposed to have an even more harsch engagement then the six puck. Although on custommaxima they have it listed the other way around. I only need the street disc, anybody can guide me on where I can buy it for the lowest price?
Andrei
Andrei
carlosvq30
Aug 17, 2015 11:32 AM
