IAVC line placement with boost.......
Old Nov 7, 2003 | 03:25 PM
Ramius83
Ok, if the MAF is on the Charged side, does the IAVC line have to go on the charge side, along with that little little line as well? Of can the IAVC line go on the non-charged side with that little line? And one more thing, can that little line just be plugged into a manifold vacuum source or just left open?
And, on another note, what side can the ambient sensor go one? I have a 96 Maxima, so my ambient sensor is the two-screw unit. I DO NOT trust this ambient sensor because I see it leaking charged air (boost). Can I put this unit on the intake side of the turbo instead on the charged side?
Thanks all.
Old Nov 7, 2003 | 04:03 PM
BigDogJonx's Avatar
Damn I aint heard from you in weeks.
Old Nov 7, 2003 | 04:43 PM
Ramius83
Yeah, I have been WAY busy with school and work. I am just about done with the kit. You still didn't help me out with this answer lololol Dixit.....
Anyways, anyone know?
Old Nov 7, 2003 | 05:41 PM
Shadow's Avatar
I think the IAVC should stay on the charged side. The little line we plugged into the vacuum tee. If you leave it open, you will have a vacuum leak. At first, on Jason's car we left it open and the car threw a code. Then we plugged it into the tee and everything was fine.
Originally Posted by Ramius83
Ok, if the MAF is on the Charged side, does the IAVC line have to go on the charge side, along with that little little line as well? Of can the IAVC line go on the non-charged side with that little line? And one more thing, can that little line just be plugged into a manifold vacuum source or just left open? Thanks all.
Old Nov 7, 2003 | 05:42 PM
Ramius83
Ok, on another note, what about the intake ambient sensor?????
Old Nov 7, 2003 | 09:59 PM
BigDogJonx's Avatar
Put the intake ambient on the charged side if you want the most accurate measurement, however i put mine on the intake side because I dont think it can seal too well and will probably be a boost leak there.
Dixit
Apr 16, 2020 05:15 AM
doctorpullit
Dec 12, 2015 09:39 AM
Taino14
Sep 24, 2015 02:51 PM
mpbclutch33
Sep 21, 2015 01:54 PM
