EGT temp problem. NEED HELP.
Old Nov 22, 2003 | 05:46 PM
190hpKiLLA's Avatar
Granny Driven
I installed a digital EGT gauge from Dynotune.org today in one of the y pipes that come down. I wasnt the one doing the install. I only did the wiring.
So when I wired everything up the EGT reads Extremely low 100-150 degrees in celcius. WTF. I ook everyhting apart myslef and installed it back together and still it reads 100-150. @WOT it read ~200+ and soonest i let go it jumped to 100 degrees. Whats going on?
Is it the probe? The location?
Can u specify what ur reading is when ur driving around and @ WOT.
Thank you.
Old Nov 22, 2003 | 09:15 PM
Nismo's Avatar
shouldnt it be in ferinheight? mine(autometer) is maybe around 6-800 idle and about 1200 cruising in 5th gear at highway speeds.
Old Nov 22, 2003 | 09:17 PM
BigDogJonx's Avatar
First off where did you install it?
2ndly, even if you installed it right before the CAT you would get a temp of that low. Seems like the probe is faulty to me.
Dixit
Old Nov 22, 2003 | 11:28 PM
190hpKiLLA's Avatar
Granny Driven
Dixit
I got it installed in a mufler shop where I get my custom exhaust done all the itme. I never had a problem with them. I think they f*cked it up because the Dynotune gauges are very fragile and they ruined it. They bended the brobe and when I took it out to look at it the tip was chipped off. So U think I should just get a new probe and go from there.
Also I used a clamp not a screw in bong. http://www.speedshop.org/store/ProdI..._bnc_large.jpg
Thank you guys.
Old Nov 22, 2003 | 11:39 PM
Chunger's Avatar
My other car is a Hybrid
It should run about 380C at idle when warm... Something wrong with installation or gauge?
Old Nov 23, 2003 | 09:02 AM
JAY25's Avatar
I had the same issue with my gauge. Turns out the ECU inside the gauge was fried since my battery post adapter broke and shorted out the Gauge. I had to buy a complete new gauge.
Old Nov 23, 2003 | 01:05 PM
190hpKiLLA's Avatar
Granny Driven
Well I have a digital gauge. can it be the probe or the sending unit?
Old Nov 23, 2003 | 02:24 PM
BigDogJonx's Avatar
Well the probe is the sending unit in effect. I think the probe is jacked up.
Old Nov 23, 2003 | 04:10 PM
190hpKiLLA's Avatar
Granny Driven
I hAVE 3 parts. the probe, the sending unit and the gauge.
What do u mean by jacked up? Broken? Thank you.
Old Nov 23, 2003 | 04:15 PM
BigDogJonx's Avatar
You meantioned that the probe has some pieces broken off it. If thats the case, then the probe is probably giving a wrong reading. That is what I meant by jacked up. Broken/deffective now.
Dixit
Old Nov 23, 2003 | 04:36 PM
SonicDust187's Avatar
If you have the dynotune gauges, plug it into my car and see if it works better.
Old Nov 24, 2003 | 03:08 AM
pblaze's Avatar
If the you can get to the connections, make sure that the thermocouple wires are not reversed. If there is a red wire, that will be negative, oddly enough. Also check that the t-couple extension wire is not damaged. For example, if the wire was crushed you might have a short somewhere between the real t-couple and the indicator. This would form a new thermocouple outside the exhaust pipe which could explain the low temps that rapidly decay.
Old Dec 3, 2003 | 07:11 AM
190hpKiLLA's Avatar
Granny Driven
Well.. i sent back the probe and the company said it was damaged. Lets hope the new one will work so i can beat on my car.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
