So, the 4th and 5th gen kits aren't exactly the same
alright, here's the skinny.
i have had that s/c off and on so many times that i think i know it inside and out.
as y'all know, i got the new bracket from stillen.
a couple of pieces were reinforced, but it has the same shape and bolt pattern.
oh yeah, it doesn't. the stand off bolts are different lengths.
(btw im planning on leaving off this bolt)
if that is alright. suggestions?
So, if i torque the bolts to spec, the idler pulley becomes misaligned and tilted.
I ran the belt to double check what i think is happening. with the top half of the bracket mounted, everything looks fine. all the pulleys are in the right place, but there is about a 3 mm gap between the standoff bolts and the bracket.
I'm thinking if i put two washers on, it will fit the gap and i can torque it onto the crankcase.
after that, im done?
can anyone think of the problems with this?
there should be no gap between the stand off bolts and the motor. They should be seated all the way in. Thats my picture with my bolt not in there. I did not have alignment issues. If in fact the stand off bolts did not thread all the way in. Then they are the wrong ones. Do not try to thread them all the way into the timing chain cover or you will snap them. That 3mm gap should make you shoot the belt toward the motor since the belt will fall inwards. Is that the direction your belt shredded
i spaced the bracket with two washers.
the stand off bolts are in the crankcase perfect.
the belt looks good, the cai is in, theres hood clearance for the bov
the water pump is connected
just a few things b4 i start her up
yes, and what happened is that the bracket shifted and made the idler pulley become misaligned
is there any gap on the M10 bolts (the bolt that holds the engine mount)? These two should be the last bolt that you torque down. if there's gap on the M10, I would add washer to these two because you can use larger washers.
since you've already added washer to the stand-off. I would carefully check the belt alignment before putting everything back. you can tension the belt to the spec, connect oil feed and return and crank up the engine few time. see where the belt lands after you crank it.
have fun.
the m10 bolts are fine, all the rest of the bolts that go into the timing chain cover are fine, its just the two at the bottom that are a little different.
maybe they changed the length of the standoff bolts for the 5th gen bracket.
could be. or that area on the 5th gen bracket is just a little bit thinner than that of the 4th gen.
MAXSE5SPD
Sep 17, 2022 04:00 AM
