Where did you tap into for the Boost Gauge?
I tapped mine in just before it hooks up to the stock Vortech FMU. Is it preferable to have it at the T where all of the hoses come together? Reason I'm asking is that I'm still getting 15 Hg vacuum despite tightening up all of the connections.
Originally Posted by Stephen Max
It shouldn't matter where you tap in as long as you're tapping into a line that has its source at the nipple after the throttle body (in between the TB and IACV). The fpr vacuum line comes from that, so if you tee off the fpr line you're good. There is another vacuum source that comes out of the bottom of the TB. That leads to the egr control valve solenoid. Don't tap in there because you will get low vacuum when the throttle plate is closed. Maybe that's your problem?
I tapped into the hose that runs into the top of the FMU. Is that the problem?
I get like 10 ~15 Hg as soon as I turn on the engine in the morning.
A low vacuum is normal when the engine is cold and the idle speed is high. Once the engine warms up and idle speed drops to 650-750 rpm, the vacuum should be around 18-20 in Hg.
litch
123
01-04-2024 07:01 PM
06-06-2017 02:01 PM
