engine specs
Old Dec 19, 2003 | 07:42 PM
stephenlc's Avatar
engine specs
I was wondering what the engine specs where on our car. Like piston size, stroke bore, stuff like that. What size our connecting rods are, floating bearing on the piston or what. I need to buy a used engine and tear the damn thing apart but for now, care to post.
Old Dec 19, 2003 | 08:13 PM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
i have a used engine in my garage and i was going to post the same thing...you me to the punch pa
Old Dec 19, 2003 | 10:14 PM
stephenlc's Avatar
I want to get some custom pistons made and connecting rods or maybe use ones made for another car if I can gets omethign close enough.
Old Dec 21, 2003 | 05:40 PM
BigDogJonx's Avatar
Man yall asking for a good bit of info...... But since its the holidays.......
Cylinder Bore Inner Diamter
Standard
GradeNo1 93.000-93.010mm
GradeNo2 93.011-93.020mm
GradeNo3 93.021-93.030mm
Piston Skirt Diameter
Standard
GradeNo1 92.980-92.990mm
GradeNo2 92.990-93.000mm
GradeNo3 93.000-93.010mm
Piston pin hole diamter
21.993-22.003mm
Piston clearance to cylinder block
0.010-0.030mm
Connecting Rod Center Distance
147.60-147.70mm
Connecting Rod piston pin bushing inner diamter
23.980-24.000mm
Connecting Rod big end inner diameter
48.000-48.013mm
Bore and store
93 x 73.3mm
Old Dec 22, 2003 | 12:08 PM
pawnstar12's Avatar
Standard
Standard
21.993-22.003mm
0.010-0.030mm
147.60-147.70mm
23.980-24.000mm
48.000-48.013mm
Bore and store
93 x 73.3mm
damn bigdog youre always pimpin it!!!
thanks man
Old Dec 22, 2003 | 01:23 PM
BigDogJonx's Avatar
You know it. Without Specs you are NOTHING!
Dixit
The Wizard
24
Oct 1, 2015 08:47 PM
seesole
Sep 14, 2015 12:38 PM
lux97Max
Sep 11, 2015 01:12 PM
Samedi
Sep 3, 2015 01:07 PM
