ACT Clutch odor?
Old Dec 20, 2003 | 01:13 AM
HNDA ETR's Avatar
Still Here... IM me for more..
ACT Clutch odor?
I had my ACT Heavy Duty clutch installed about 3 months ago.
Got my S/C installed about 1 month ago.
Just started smellin' what seems to be clutch material - pretty nasty smell...
I'm not abusing the clutch - ie: no clutch drops, no burnouts and not riding the clutch...
Anyone have this kind of experience?
Could it be that the ACT cannot handle the load when I'm driving 80 mph and then drop it into 4th and punch it?
I'm puttin 265whp...
Old Dec 20, 2003 | 11:09 AM
MaximaRider's Avatar
it should DEFINITLEY be able to hold the load, i think its upto 350hp 350tq rating. Either way i'd like to know as well, my act gets installed this month along with the V2.
Old Dec 20, 2003 | 11:22 AM
Craig Mack's Avatar
All YOUR grammer belong to me
What stage is it? I had a stage II and never got a burning smell. It was an excellent clutch, and held all the power my boosted Max threw at it without a bit of trouble. I now have a SPEC stage I clutch in my Cobra, and have gotten a really nasty burning smell. I called SPEC and they told me it's normal and part of the break in, becuase the clutch is made up of a lot of metal/kevlar. The ACT stage II is organic if I remember correctly, but if you have another stage, and it's made more of metal/kevlar, then the burning smell is just the new clutch breaking in.
Old Dec 20, 2003 | 11:50 AM
HNDA ETR's Avatar
It's a stage 1 I believe... the Heavy Duty organic one...
I've got at least 2000 miles on it, so I wouldn't think that it's still in the break in phase..
It seems to hold ok though... matter of fact, when the boost kicks in hard in 1st gear, the wheels start to burn out...
Old Dec 20, 2003 | 12:19 PM
hlh0501's Avatar
ACT doesn't use stages. Is it the common NM1-HDMM package, which is their street clutch disc with heavy duty pressure plate?
If so, that is what i use and it holds 600hp+ and 600+tq just fine, even while on slicks (although its not fond of the big burnouts) Does it just smell, or is it slipping also - I would assume if it smells its slipping. You're sure it's clutch you smell? Try getting a second opinion if you are not sure
Does it do this immediately if the car has been sitting for a while? Or only when you have been driving for a bit? You may have the master cylinder rod checked out to make sure it is adjusted properly.
Good luck
Old Dec 20, 2003 | 12:33 PM
HNDA ETR's Avatar
Good luck
I don't feel it slipping, it just started smelling out of the blue... The smell shows up after I've been driving it...
The clutch is hydralic, how can it be adjusted?
thanks for the info guys!
Old Dec 20, 2003 | 01:18 PM
hlh0501's Avatar
There is a rod going from the master cylinder through the firewall that connects to the back of the clutch pedal. It is threaded and can go in and out. I would not mess with it unless you truly know what you are doing with it though, or you will make more problems. If it is improperly adjusted, over time (driving, using the clutch pedal) it will build up pressure and cause the clutch to not fully engage, etc. I am not sure if that sounds like your problem
Old Dec 22, 2003 | 07:25 AM
JAY25's Avatar
I agree with you. I have a ACT and I dont have not such smell or smoke coming out of my tranny. Need to fix that issue very fast before you end up purchasing another clutch kit.
Old Dec 22, 2003 | 12:01 PM
Stephen Max's Avatar
I got the nasty smell a couple of times, but that was due to me easing the clutch out too slowly during a boosted 2-3 shift. Lots of slip at high rpm = lots of heat.
Old Dec 22, 2003 | 01:20 PM
JAY25's Avatar
I dont shift slow, I shift very fast. The only time I got clutch smell is when I sat at the light and tried to do a burn out. That was driver error me.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
zmcneely13
Sep 26, 2015 02:26 PM
carlosvq30
Sep 26, 2015 09:44 AM
carid
Sep 17, 2015 05:00 AM
