Max HP on 91 octane?
Old Dec 21, 2003 | 01:00 AM
I30tJim's Avatar
Anyone have an idea of the approximate amount of hp you can run on pump gas?
I know there are numerous conditions that affect this like weather, compression ratio, Intercooler, NOS, etc..
What would the max hp be, with totally optimal condtions to prevent detonation, with say 9:1 cr on our cars?
Old Dec 21, 2003 | 07:24 AM
on_alert's Avatar
Realistically, That question is impossible to answer. You say 9:1 CR, but without getting really crazy with saturation limits of atomized fuel you could really get any number you wanted too. Assuming 9:1 CR, that means that the motor is already built, so are you running 25 psi boost pressure? Optimal conditions... well, can we assume that you intake temperatures are 32 degrees? If you go crazy enough with your motor, you can more than enough HP to destroy the VQ block, If thats what you are after...
Old Dec 21, 2003 | 02:03 PM
I30tJim's Avatar
Actually the answer Im after is whether or not 9:1 is too high for max hp on pump gas. Ill give you a better setup to work with:
PFI turbo kit, 60-1 turbo, 9:1cr, would 500hp be possible with 91? no NOS like Hal
Is 9:1 too high for 500whp? Im thinking that I should have gone with 8.5:1
Old Dec 21, 2003 | 04:49 PM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
im not 100% but i wouldnt try it. i would make a low compression head gasket like in this thread
http://forums.maxima.org/showthread.php?t=272031
and get a J&S then you will good to go for def. why the pfi kit? dont you think its too much for the quality that you get? and you should be looking for forged rods
Old Dec 21, 2003 | 06:06 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I agree with the above...and even so if you are already down to 9:1 there is VERY little to worry about already. so combine that with a method to retard timing per lb of boost or with J&S you'd be good to go. 9:1 is perfect...I've seen many 9:1 Hondas well into the 400s and many off the shelf pistons the common low CR options are usually 9:1 or 8.5:1...thats plenty suffiecient of a drop as long as you consider your fuel and timing issues as well.
Old Dec 21, 2003 | 06:54 PM
I30tJim's Avatar
Thx for the help guys
Old Dec 21, 2003 | 06:56 PM
I30tJim's Avatar
For the money they offer more options than any other turbo kit Ive seen besides Hals, which isnt around anymore. I was not aware that PFI had poor quality, ive only heard good things about it. I will let you know what I think when it gets here.
Old Dec 21, 2003 | 08:01 PM
stephenlc's Avatar
Is 91 octane the highest you have in your area?
Old Dec 22, 2003 | 01:35 AM
I30tJim's Avatar
yes, California
Old Dec 22, 2003 | 12:05 PM
pawnstar12's Avatar
i have an auto and they were giving me some bulls*it price just for the piping and they said you cant put an intercooler in there either they just ****ed me off so i got a custom made jammie! and im mad happy.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
