WTK Why V2 from 97-98 doesn't fit 99
Old Dec 22, 2003 | 05:28 PM
C3nthusiast's Avatar
Why wont an SC from a 97-98 fit a 99?
Old Dec 22, 2003 | 06:09 PM
JAY25's Avatar
I can tell you this much, I have a kit for 99-2001 and it bolted right up to the 98 spare engine I have in my garage. In a about 8 weeks this 5th gen kit will be bolted up to my 95 daily driver
Old Dec 22, 2003 | 09:37 PM
MAXimumHP's Avatar
I think the 99 and newer kits will work with the older cars, but not vice versa.
I think the 99 bracket is different in that it stands farther away from the block to clear a redesigned timing cover. I've never seen both, but I thought I read this somewhere on here before.
Old Dec 23, 2003 | 05:34 AM
JAY25's Avatar
so Nissan redesigned the timing chain cover from 99-2001? why would they do that?
Old Dec 23, 2003 | 07:45 AM
MAXimumHP's Avatar
I have no idea, but they changed all kinds of other stuff so it wouldn't surprise me. I thought that is why the bracket is different. I have a 99 and will compare mine with my Dads 97 and see if I can find any differences.
Old Dec 23, 2003 | 08:06 AM
MAXimumHP's Avatar
Here's something I dug up that SighMax Discovered.
I had the 98 bracket installed on my car originally, but because the way it was mounted to to timing chain cover, it ended up cracking the lower part of the cover and started leaking oil. The locations for the bolts and the size were the same but Nissan made the base where the bolt goes in narrower on 99. Stillen had to refabricate the bracket to make that part narrower.
The contact point on the bracket to the timing chain cover on the '99s are narrower than the previous years. If you use the previous year's bracket on 99, you may crack the t-c cover and it will start leaking oil. I don't believe there are any other major differences including all the contact points. Therefor, you should be able to use the 99 bracket on the previous year engine. You can probably use non-99 bracket, but the stress caused by the contact point will eventually crack the timing chain cover.
Old Dec 23, 2003 | 12:25 PM
JAY25's Avatar
I am pretty hardheaded, I am still going to bolt that 99-2001 kit to my 95 daily driver.
Old Dec 23, 2003 | 01:05 PM
MAXimumHP's Avatar
It will work, it's putting a 95-98 bracket on a 99 or newer that causes problems.
I may buy the next SC kit for sale to see if I can make it fit on a 99. All one would need to do is taper down the mounting points so they don't put pressure on the timming cover. Or maybe change out the cover with one from a 97 or 98.
Old Dec 23, 2003 | 02:58 PM
WizzaMax's Avatar
I was selling my 99 kit a while back...no one was interested....so let me know...it has been removed and has only been polished since then just to pass time...i had considered putting it back on but depends if it sells.
PM me for more information...pics on website.
Old Dec 23, 2003 | 04:39 PM
JAY25's Avatar
Ill take a closer look when I install my kit on my car. Lets see if any belt issues arise. I hope not but if it bolts up as long as all my pullies align I should be fine.
Old Dec 23, 2003 | 07:52 PM
MAXimumHP's Avatar
Good luck and keep us updated.
WizzaMax:
My wifes sister died today so I'll be a little busy until the new year. I'll send ya a PM when I get a chance.
Old Dec 23, 2003 | 11:27 PM
WizzaMax's Avatar
wow, sorry to hear,,,thats sad man....take your time and take care of the family...best wishes to you and yours.
Old Dec 24, 2003 | 08:09 AM
MAXimumHP's Avatar
Thanks.
I sent you a PM concerning the SC
MaxiNoob98
Oct 2, 2015 10:13 PM
jchronis2552
Sep 23, 2015 04:57 PM
carid
Sep 9, 2015 05:06 AM
