Definitive Answers?
Still Here... IM me for more..
Definitive Answers?
Ok,
So I've read all the threads about the 2000 Maxima, Injectors, MAF, etc...
but I'm still not 100% clear on some things:
1. What size injectors do the 2K Maximas have? 295, 259, 245, ?
2. Are there any injectors that will replace the 2K's? (M45, Q45, etc?)
3. 370cc injectors from the 300ZX do NOT work with the 2K, right?
4. 350Z injectors are the same/same size as the 2K Maxima injectors?
5. Where can I get an upgrade/replacement MAF for the 2K Maxima?
6. The stock 2000 Maxima injectors are good up to 350fwhp?
7. There are no aftermarket fuel rails for the 2000 Maxima, right?
Sorry guys, but all the different answers in all the different threads is confusing...
Ummm, I am not sure on this. I think the 2k injectors are 259 and the 2k's share the same injectors as the 350z. You can use all aftermarket injectors for the 350z which are much cheaper than Nismo injectors which I have to get. I think you can use any MAF if you know how to program it. There is an Apexi program called big air controller or something like that. It lets you program the bigger MAF so you can run it on stock ECU. I think the 2k injectors are good for about 325-350 whp to be safe. You can always get someone to make you custom fuel rails. Just need a cad design and a shop the cuts billet aluminum with a machine.
jerrod99_se-l
09-25-2015 03:02 AM
Keyno McMike
09-21-2015 07:18 AM
