best clutch for V2
Old Jan 13, 2004 | 10:03 AM
cardana24's Avatar
Blown
best clutch for V2
I am in the market for a clutch and I have been looking at the ACT and the Exedy stage one clutches...in your opinion which one would hold up better and be less harsh on the transmission? From what I have read I am leaning toward the exedy, but I would like opinions or experiences. Thanks.
Carson
Old Jan 13, 2004 | 10:32 AM
ejj's Avatar
ejj
The ACT will hold just about all the power the SC can throw at it, and won't cause any damage if you use your head.
Old Jan 13, 2004 | 10:37 AM
cardana24's Avatar
Blown
ok, I have also read that the exedy has the same griping power but it is easier on the transmission...any opinions?
Old Jan 13, 2004 | 11:00 AM
JAY25's Avatar
Hes correct. Like I said before drivers blame the **** on the clutch. All three of my cars have ACTs. The one 95 max has a ACT PPl and stock disc. It transfers all the power. If you know what your doing when you start off in 1st and 2nd gear you should not have any problems. Our tranny cases are pretty thin and any clutch could break it. Hows that? improper take off, doing burn outs on trays, letting the wheels hop for an extended period of time and the list can go on.
ACT great clutch for the money it holds all the power you throw at it.
Exedy I have not seen anyone thats pushing over 300HP with one. If someones out there pushing 300HP with an exedy clutch they need to post. I am pushing 325HP 307lbs of torque w/ACT stage 1 the street setup.
Old Jan 13, 2004 | 11:02 AM
jdmmax's Avatar
i am using a clutchnet 6puck sprung disk with an exedy pressure plate.
Old Jan 13, 2004 | 11:50 AM
subs1000w's Avatar
thats funny im using a clutchnet 8puck sprung hub disc with an act pressure plate
the disc is this one
Old Jan 13, 2004 | 12:27 PM
cardana24's Avatar
Blown
ok so it sounds like the act is the way to go...when I was talking about the exedy clutch I was talking about info I got from NA guys....also does clutchnet make a clutch kit? And if so where can I find it? Thanks.
Carson
Old Jan 13, 2004 | 08:02 PM
subs1000w's Avatar
yes you can get a kit from clutchnet but there not cheap somewhere in the range of 400$
should be able to go to www.clutchnet.com to order one
the only reason i went with my setup is i had perchased a used act clutch kit which had a solid hub 6 puck disc and after some searching and thinking i desided i better not run it so i bought just the clutchnet disc because all my honda friends run clutchnet kits and i drove one and i liked it plus the disc was only 25$ more than a new ACT street disc so i figured what the heck
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
