i made my own turbo kit, HOW DO I INSTALL?
Old Feb 10, 2004 | 08:56 PM
ProData's Avatar
can anyone send me a link on how to install a turbo kit in a 97 max? im new to max tuning and install. is this good setup for fuel for 9psi.
370cc
s-afc
jwt chip
msd boost retard
Old Feb 10, 2004 | 09:13 PM
KLoWnPR109's Avatar
Please, do inform us of the details of your "kit"
Old Feb 10, 2004 | 09:37 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
interesting thread....BTW msd boost retard doesn't work on DIS ignitions
Old Feb 10, 2004 | 10:09 PM
Shadow's Avatar
This may be a really silly question. But exactly how do you make your own turbo kit yet have to ask us how to install it?
370cc
s-afc
jwt chip
msd boost retard
Old Feb 10, 2004 | 10:27 PM
maximase86's Avatar
I love lamp.
This is funny. You made your own kit and you don't know how to install it. I hear the dealership will give you a good deal on your turbo install!
S
Old Feb 10, 2004 | 10:51 PM
Redmax's Avatar
Redlinemax Owner
I was thinking the Same thing!!!
Old Feb 10, 2004 | 11:05 PM
DAVE Sz's Avatar
Hooooooonda.....
All the pipes should be numbered so just line them up in the correct order. Really hope that helps.
Old Feb 11, 2004 | 07:34 AM
stephenlc's Avatar
How could you build a kit and not know how to put it together. You are not being serious right?
Old Feb 11, 2004 | 07:43 AM
subs1000w's Avatar
break out the duct tape
hahaha SLAP
Old Feb 12, 2004 | 08:54 AM
on_alert's Avatar
what the hell?
Old Feb 12, 2004 | 09:20 AM
ProData's Avatar
Sorry to not inform you better.
i mostly build and tune turbo hondas, my friend has just got a 97 nissan maxima. he wanted to buy the kit but i told him that i can peices on out for him and tune it.
i got a the:
turbo w/ heat shield and accersories = ebay $250
tail wastegate = used $50
all flanges = have a plasma cutter , cut my own out
intercooler = $200
i can fabricate all the intercooler pipes and ypipe, full cat-back= free
z32 tt MAF= used $70
255 fuel pump = $80
Fuel regulator = $100
370cc /300zx injectors= used , sent to rc to get checked, $100
dsm blow off valve = Free
apexi S-AFC= used $100
JWT custom chip = $300/ just want the eprom changed to my specs
CC stage 2 clutch = shop discount $250
TOTAL: 1500
i have a shop and i also have a wideband to tune it first to 12:1 then take it to the dyno. ill have a boost controller to move from 4psi daily to 10psi on a stock motor.
i usally work more with hondas put have never worked with nissan turbo, i can see pic of the install ad know where it goes , but besides moving the battery to the back and the stock intake box, what els do i need to fabricate to fit the turbo in there. thanxs
Old Feb 12, 2004 | 09:24 AM
on_alert's Avatar
tail wastegate
all flanges
intercooler
z32 tt MAF
255 fuel pump
Fuel regulator
dsm blow off valve
apexi S-AFC
JWT custom chip
CC stage 2 clutch
TOTAL: 1500
sorry, i had to
Old Feb 12, 2004 | 09:32 AM
stephenlc's Avatar
Wow 1500 dollars. The JWT ecu is like 600 by itself.
Hook a brother up!
Old Feb 12, 2004 | 09:36 AM
|Bijan|'s Avatar
UCF Lexus
something just doesnt add up....
Old Feb 12, 2004 | 09:39 AM
on_alert's Avatar
NEVERMIND ON THE BS FLAG...
I just realized you must have meant 1500 '3 dollar' bills....
yall
Old Feb 12, 2004 | 09:44 AM
ProData's Avatar
Hook a brother up!
Im here just to get help on install tips , oK i don't reall care if you guys think my setup is BS, you don't know me.
I thought people here that actuall have installed their turbo kits could give me some tips!
the Jwt ecu i got used from a 96 maxima that has already been preped for 370cc and the z32 maf.
Old Feb 12, 2004 | 10:34 AM
on_alert's Avatar
I didnt mean any offense, I am really sarcastic whenever I type anything. Anyways i have some slightly more detailed pics here, maybe they can be a start.
http://www.eng.buffalo.edu/~ctnewman/turbopictures
also, i think it has been discussed before, but unless that JWT ecu has been programmed for boost, I dont think you will get enough fuel out of it + Z32 injectors/maf. I could be mistaken tho.
I think this has been covered, and it should be easy to figure out mathematically based on current FMU users FP/boost settings on stock injectors compared to what you can flow at base fuel pressure with the Z32 injectors at 95% duty.
I can take the time to figure it out if you cant find it elsewhere.
Care, on sharing where you got all that stuff so cheap?
Old Feb 12, 2004 | 10:45 AM
maximase86's Avatar
I love lamp.
Wow dude....you could at least of said something like that. From what you typed, I was under the impression you just bought a all this stuff, but don't know what to do. Sorry if that statement I made before comes off offensive...but it was all meant in good fun of course. Just be a little clearer sometimes, because here....it's very easy to misunderstand someone.
S
Old Feb 12, 2004 | 10:50 AM
ProData's Avatar
S
its cool , i know how it is! yea i custom make kits for honda its much easier. this favor is for my friend. you can look around on ebay, honda tech , any car fourm they have a classified where they sell stuff. look around you can fine real cheap used parts.
Old Feb 12, 2004 | 11:06 AM
ProData's Avatar
WOW thanx so much that all i need! you are the man, know i know what to do thanxs so much.
i got to buffalo state, i live on lisbon ave, do u go to buffalo????
Old Feb 12, 2004 | 11:27 AM
on_alert's Avatar
holy crap. I used to go to HC shows on lisbon all the time. I graduated from UB and am a mechanical engineer, but I will help you with the project if you want, Id like to! I am OK at welding. Where is your shop? I will help you if you let me use your dyno to tune my RB26dett.
EDIT: I live in hamburg, BTW
Old Feb 12, 2004 | 11:32 AM
hlh0501's Avatar
A quick look over your list and I didn't see what you had to install so much as needing to, well, you said it best:
"i can fabricate all the intercooler pipes and ypipe"
If you get so far as fabricating the feedpipe, then you're doing good and shouldn't need help "installing" a pipe you just created on the car.
check out my website for a examples & help.
on_alert's Avatar
PS: are you on UBRF.org???
Old Feb 12, 2004 | 12:23 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I feel like I just watched a mini soap-opera or something.
Old Feb 12, 2004 | 01:51 PM
ProData's Avatar
what is your screen name AOL? im also in the mechanical engineering program. where do you work now as a mechanical engineer? My shop is in albany i just got to school in buffalo, might stay for part of the summer, also might bring my integra up. i can bring my wideband and we tune the can the A/F.
Old Feb 12, 2004 | 03:41 PM
thebigsadler's Avatar
250 for turbo? 200 for intercooler?
and you think those parts will hold 9psi and put down good numbers? odd.
best of luck.
Old Feb 12, 2004 | 05:10 PM
subs1000w's Avatar
no offence but ive seen alot of used T3/T4's and T4's go for around 250 on ebay and i dont see why they wouldnt do 15psi more or less 9. ill have to see in the future when i buy one but im not worried because i know a honda guy at school who has an ebay t3 on his car and it works just fine
Old Feb 12, 2004 | 06:02 PM
stephenlc's Avatar
What does it matter what he payed for it. I know at least 20+ people that have used turbo and payed anywhere from $250-300 dollars for them. Just because it is not new does not mean that it does not work well.
Old Feb 12, 2004 | 06:18 PM
i was just saying you never know what you are getting.. and not to make assumptions that things will work right.
why not just buy it new?
Old Feb 12, 2004 | 08:12 PM
stephenlc's Avatar
Not eveyone is a baller like you Jason.
Old Feb 12, 2004 | 08:20 PM
riiiight..
and people wonder why things break a month down the road when they try and scrounge for used parts or cheap parts.. i just think when messing with something like this, you should spend the extra money.
Old Feb 12, 2004 | 08:35 PM
ilumo's Avatar
riiiight..
Theres nothing wrong with buying used... Just do your research ahead of time, and know what you are agetting into. I bought my current S/C setup used... and im pretty sure it is FINE. no probs yet
Old Feb 13, 2004 | 05:02 AM
DA-MAX's Avatar
best of luck.
www.homemadeturbo.com
yes, its very odd...
stephenlc's Avatar
Jason I am just saying not everyone has 10+ k to dump into their car.
Old Feb 13, 2004 | 05:31 AM
|Bijan|'s Avatar
UCF Lexus
But more like $20k
Old Feb 13, 2004 | 05:07 PM
it's also a vortech unit made for this car correct.. slightly different from a random turbo that could be used in some kit?
10k... 20k.. wish it was that much, but what does that matter at this point, even if i spent 1k, i would still have the mentallity of buying a quality part. i'm not trying to beat a dead horse here, you have a valid point.
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
