HELP, Built Engine Nightmare
Old Apr 15, 2004 | 06:15 PM
I30tJim's Avatar
After waiting nearly 6 months for 9:1 forged pistons, my former mechanic put in the pistons and everything seemed to be fine, the car ran smoothly. So I took the car to XS-Engineering to have them put the turbo kit on. I get a call a few days later saying that there was unusual pieces in the oil pan like peices of metal possibly from the rod bearings. So they got the Ok to open her up and inspect everything and flush it all out. Today, I get another call from XS and they have some "very bad news". They want to know who built the engine and I said a small body shop in Gardena.
This is what XS then tells me: Some of the rods were put in backwards and that they have oil squitters on them and that they will need to rebuild the engine.
My question is do we have oil squitters on our rods!? Is this possible? He told me that he will take pictures of everything and document it so I can take my old mechanic to court. I trust XS but I dont understand how this could have happened.
Old Apr 15, 2004 | 08:50 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I know SR20DETs have oil squirters that spray the backside of the pistons that regular SR20s don't. Never heard of them in a VQ and I've seen pictures of a couple torn down and never seen any.
Can you even put in a rod backwards?
Man...so sorry to hear that, but XS-Engineering are super reputable according to what I've read, so I'd go with what they're saying.
Good luck~! Keep us posted.
Old Apr 15, 2004 | 09:09 PM
Dreizehn's Avatar
From what I understand, the VQ35 has oil sprayers that spray the underside of the pistons. I'm guessing you had a VQ30 built, they don't have the oil sprays. (I don't recall when the oil sprays were added... to the VQ30DEK or to the VQ35, if someone knows please clarify.)
What he could have done was install the main bearings backwards. There is pressurized oil that is pushed into the crank. Which then gets pushed into the rod bearings. If he installed the main bearings backwards, it would have blocked that oil. Given it time, that motor would have seized or spun a bearing. If that is indeed the case.
Another thing could be that he didn't size the bearings correctly. Not sure...
The stock rods do carry a "front" mark on them now that I think about it. I'm not sure the signifigance of that without diggin into it.
Keep us posted as to what was done to that motor. Good luck!
Old Apr 16, 2004 | 02:35 PM
I30tJim's Avatar
Thanks for the help, I guess i will just go with whatever they say, maybe I am not understanding something.
Old Apr 17, 2004 | 04:51 PM
nostrixoxide's Avatar
I30tJim
I just checked my repair manual & and the rods are marked & directional. In the (connecting rod & bearing installation) area the first thing they say to do is make sure to note the markings on connecting rods where the bearing cap connects to the rod. I have rebuilt a few honda's in my day "not to compair the VQ to a honda or anything" & they are the same way. Each rod is individually marked, the marking is half way on the rod & the other half on the rod bearing cap. Honda's are marked (1, 2, 3 & 4) to make sure you put them back in the same place they were removed from. My guess is that your mechanic is more familiar with domestic engines & he didn't realize the each bearing cap is specific for each rod. He more then likely put the wrong bearing cap on the wrong connecting rod.
I would make sure he is liable for any damages & repairs that will need to be made. Another thing you should do is inform him right away about what the other shop has told you. He absolutly must look at the engine before the other company dissasembles it. This is for your protection incase it is taken to court. If the mechanic autorizes XS to complete the tear down for him, make sure that you point out to them to make sure the rod's aren't damaged, the crankshaft is still balanced & not damaged etc. I hope you can get it all squared away, good luck & remember to post the time slip's once everything is back to normal?
Old Apr 17, 2004 | 10:16 PM
BrianV's Avatar
Originally Posted by nostrixoxide
I30tJim
I would make sure he is liable for any damages & reairs that will need to be made. Another thing you should do is inform him right away about what the other shop has told you. He absolutly must look at the engine before the other company dissasembles it. This is for your protection incase it is taken to court. If the mechanic autorizes XS to complete the tear down for him, make sure that you point out to them to make sure the rod's aren't damaged, the crankshaft is still balanced & not damaged etc. I hope you can get it all squared away, good luck & remember to post the time slip's once everything is back to normal?
Wow, thanks for the info. That sounds to me more like what might have happened. I will talk to XS Monday and get more info and post.
Old Apr 17, 2004 | 10:19 PM
I30tJim's Avatar
OOPS using Brians computer. Ill let you know what they said.
Old Apr 20, 2004 | 05:57 AM
BrianV's Avatar
The real BrianV this time:
Don't you have aftermarket rods? I'd ask whoever made your rods if that's the case.
Old Apr 20, 2004 | 06:17 AM
Chinkzilla's Avatar
man... Jim at this point you should just sell your turbo kit, use the money for a motor swap, put in a stock low mileage VQ and leave it at that. It's too sweet of a car for you to be blowing up every 10,000 miles.
Old Apr 20, 2004 | 06:21 AM
BrianV's Avatar
My recommendation = Corvette
Old Apr 20, 2004 | 07:26 AM
DAVE Sz's Avatar
Hooooooonda.....
Were the people who installed all the stuff the same people who told you the vq30 had forged rods? Am I thinking of the wrong guy here?
Old Sep 24, 2004 | 06:25 AM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
Old Sep 24, 2004 | 11:00 AM
Prodeje79's Avatar
Didn't you buy these? We already told you about this?
Old Sep 24, 2004 | 11:08 AM
pawnstar12's Avatar
i was away from the ORG & any computer access when i got them. i had someone else bid for me. i just found out today about these bad luck pistons. the pistons and rods look new and i had a bunch of my boys check them out and they look fine.
Old Sep 24, 2004 | 11:11 AM
Jeff92se's Avatar
I'm needing a caw
You need to get them magnafluxed for crackes and have them measured for straightness
Old Sep 24, 2004 | 11:14 AM
pawnstar12's Avatar
F@ck!! i guess thats what i get for not being on the org everyday!
Old Sep 24, 2004 | 11:17 AM
Prodeje79's Avatar
he says you can return them if you want in one of the threads.
Old Sep 24, 2004 | 11:20 AM
Prodeje79's Avatar
http://forums.maxima.org/showthread.php?t=333113
Old Sep 24, 2004 | 11:21 AM
pawnstar12's Avatar
well im gonna get them checked 1st
Old Sep 24, 2004 | 04:50 PM
IceY2K1's Avatar
Goooooooooood luck.
Old Sep 24, 2004 | 06:06 PM
I30tJim's Avatar
Dave, I PM'd you,
I will gladly take them back as I promised, but please have your mechanic check them out. Mine said they were perfectly fine, if you need reassurance you may contact Probe Industries, they made the pistons for me, and they too will verify the pistons are good to go!!
Jim
Old Sep 24, 2004 | 07:53 PM
Dave, I PM'd you,
Jim
Wow, you had Probe Industries make your pistons for you? There located in Lancaster, CA correct? They absolutely make high quality products, there just alittle pricey for most. I never knew they were taking on the import market, usually they just stick with american engines parts 426 hemi etc. I guess if you have enough money anything is possible! If you don't mind me asking did these a custom order only, or do they stock the pistons needed for the VQ? Thanks.....
Old Sep 25, 2004 | 11:07 AM
pawnstar12's Avatar
nos- i think they were custom made
jim- thanks for the pm and im very optimistic about the situation
Old Sep 26, 2004 | 01:11 PM
I30tJim's Avatar
Nos,
yes they were custom made.
pawnstar,
glad to here it
shilov
Feb 19, 2024 09:40 PM
Mar 12, 2020 12:06 AM
wingnut2006
Sep 19, 2015 06:13 AM
seesole
Sep 14, 2015 12:38 PM
sdotcarter
Sep 2, 2015 09:53 PM
