blow off valve vs. compressor bypass valve?
Old Apr 16, 2004 | 11:02 AM
dadiesel's Avatar
What is the difference between a blow-off valve and a compressor bypass valve? And do I need either of them on a 01' Stillen S/C w/3.33 pulley?
Old Apr 16, 2004 | 11:48 AM
BigDogJonx's Avatar
Blow off valves are normally open air blow offs. Which means when your let the gas go the excess charged air is blown off into the atmospehere.
Bypass Valves actually take the excess charged air and re-circulate that back into the intake pipe of the SC or Turbo. Most car manufacturers and turbo/sc kit makers do this to make it smog legal.
And you need ANY one of the two if you have any type of SC or Turbo. Im sure your Stillen came with the stock bosch bypass valve unless you bought it used or had it replaced.
Dixit
Old Apr 16, 2004 | 11:51 AM
Stephen Max's Avatar
I'm not sure what the difference is in functionality. They both open when manifold vacuum is high (when the throttle is closed) and stay shut when manifold pressure develops. Same animal with different taxonomy?
(Edit: Dixit answered this.)
You can run without either (I have for a short time) if you block off the bov exit port on the crossover pipe. You will get some interesting noises, though, due to compressor surge when you close the throttle at high rpm.
Compressor surge is reported to be bad for compressors, but I have never heard exactly what damage is caused.
Old Apr 16, 2004 | 12:47 PM
BigDogJonx's Avatar
Here is a small snipit about why compressor surge is bad. Makes sense.
Dixit
Compressor surge is where are after the compressor is at a higher pressure than the compressor can generate. This causes airflow in the compressor housing to back up and stall. As a result, pressure drops allowing normal airflow until pressure builds back up and stall again occurs. Extreme compressor surge is a very very bad thing, resulting in a sharp and violent oscillation of the compressor wheel which 99% of the time takes the turbo thrust bearing with it and bye bye turbo and usually bye bye motor. Avoid crossing over the surge line AT ALL COSTS.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
tseng1023
Oct 15, 2015 08:30 AM
Noela
Sep 26, 2015 08:22 AM
