View Poll Results: Who's got lowered CR?
Lowered CR
50.00%
stock CR
50.00%
Voters: 4. You may not vote on this poll
How many are running boost with lowered CR?
I keep hearing that you should lower the CR to 8:1 or 8.5:1 when boosted but I barely see anyone here with lowered compression. I know a few guys do but most I don't think are.
i have low compression pistons however they came with the engine. if you're wanting to go with high boost you'll want low compression pistons, however... if you are good at tuning you can actually run high compression and high boost. i've heard of cars running something like 12:1 compression and still pushing 20+ psi of boost. its all in the tuning.
Originally Posted by slammed95
You want to use the highest compression you can get away with. This increases torque and produces more power off boost.
10.3:1 and 5.5psi is no problem.
Originally Posted by maxlinegtr
u know where and how much it would cost to do CR pistons
Really? I heard the opposite. Running 8:1 or 8.5:1 is supposed to be optimal for boost. The chances for detonation are very slim and you get most power from that. That also makes using street gas safer.
Originally Posted by jkklim
Uh nope those are mine already, the whole thing, block rods and pistons. Will be in my garage in about a month.
I like keeping the stock CR and limiting my boost. That way I have a car that feels great driving around town but still has some ***** when I need it. Some day I might raise boost and lower the CR to 9 or 9.5:1, but not any lower than that.
IMO, id say no lower then what mingo suggested. Its not like your going to go out and run 20+psi but with a 9:1 you should be safe to run as high as 15 or so.
What really matters is how strong your bottom end is, you can run 10.1:1 compression pistons with 15psi, but thats only if your bottom end can handle it. It would be great if you can build your bottom end & get stronger rods...which reminds me that the 3.5 bottom end does fit into the 3.0block does it not
That combined with 9:1 pistons might just be a good budget build to satisfy to boost happy guys on here. Especially the turbo guys. Just a suggestion.
Originally Posted by matty
Your pretty much safe running a 10-12 psi supercharger kit on stock CR correct with 130K miles on the engine with good compression ??
-matt
-matt
The turbo however is a diff story, depending on the turbo it can reach full boost as early as 2.5K so your putting the stress of boost on the motor from that point on. So a turbo is definetly harder on the motor.
6spd4dsc
03-04-2016 05:19 PM
dvcamp
09-18-2015 10:17 AM
trungg86
09-04-2015 04:58 AM
