Oil Pressure and Water Temp gauge install help needed.
Old May 23, 2004 | 01:34 PM
95CustomMaxima's Avatar
I just got my Oil Pressure Guage and Water Temp gauge from Autometer. I am in need of some help wiring it up. I know where to wire the light source, but need to know where to tap for the water temp gauge and what/where do I put the Oil Pressure switch that came with the Oil Pressure gauge. Any help would be greatly appreciated. Pics and writeups would be awesome.
Please help me out guys...
Thanks,
-Nick
Old May 30, 2004 | 12:35 PM
BigDogJonx's Avatar
The Oil pressure sending unit needs to be T'd off on the oil sending unit line going to your s/c or turbo. If you got no turbo or s/c, then you need to tap it at the oil sending unit on the upper oil pan.
Water temp, well not easily done, in my opinion why do you need this? Does your incar gauge not work? Water temp gauge isnt as important as other gauges like oil temp, egt, etc... If its a standard reading gauge, then just tap it to the water temp sensor on the drivers side of the engine near the block.
Dixit
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
acw
Aug 7, 2015 04:20 PM
